05-15-2015, 01:47 PM | #1 |
Newbie Join Date: Jun 2013 Location: Burlington
| Steering upgrade
I'm building my own steering tie rod and drag link for the wraith. Can anyone help me in the length of the rod has to be? Sorta like the vp one. I know the traxxas ball ends i use total 5/16 but any help would be useful. MM or inches
05-15-2015, 01:55 PM | #2 |
Quarry Creeper Join Date: Mar 2014 Location: san antonio
| Re: Steering upgrade
copied these measurments from rc4wd'a website for the links they sell for the wraith: •1x 163mm Bent Front Steering Link (Black) •1x 70mm (2.75") Internally Threaded Aluminum Link Aluminum Steering Link Kit for Axial Wraith (Wraith, Ridgecrest) |
05-15-2015, 01:59 PM | #3 |
keep in mind you'll have to add a little to those measurements if you pan on using threaded rod so you have enough to screw the rod ends on to.
05-15-2015, 02:21 PM | #4 |
Thanks. Im using full stainless steel rod. I just tap the ends so its solid. no tubes.
05-15-2015, 02:27 PM | #5 |
| Re: Steering upgrade you'll still need to add a little length to the rc4wd measurments. again, you need something for the rod ends to screw on to. Their measurements are based off links that have been drilled and tapped.
Steering upgrade - Similar Threads | ||||
Steering upgrade | Satheddal | Axial SCX-10 | 8 | 05-22-2014 08:00 PM |
HR Steering Upgrade | Farmers00 | Vaterra Twin Hammers | 2 | 04-02-2014 07:00 AM |
upgrade steering help. | jeremyfowler33 | Vaterra Twin Hammers | 15 | 03-30-2014 12:00 AM |
Best Steering upgrade | 2004DE_JR | Axial Wraith | 13 | 02-28-2014 10:05 PM |
Steering upgrade | crawlernut | G-Made Crawlers | 50 | 02-09-2014 11:16 AM |
