Thread: Revolver S stubby in a wraith?
Old 05-21-2015, 03:06 PM   #1
Default Revolver S stubby in a wraith?
Has anyone put a Holmes revolver stubby in a wraith? Will it have good wheel speed? I tried searching but couldn't find anything.
novarider is offline   Reply With Quote
Old 05-23-2015, 04:29 AM   #2
Default Re: Revolver S stubby in a wraith?
Anyone?
Old 05-23-2015, 08:41 AM   #3
MODERATOR™
EeePee's Avatar
I'd get the regular size one.
EeePee is offline   Reply With Quote
Old 05-23-2015, 08:46 AM   #4
They are sold out
Old 05-23-2015, 10:31 AM   #5
Just got one installed and tested, some issues....but I may have set it up not correctly.. I have to investigate further ..
I read someone on this forum having issues I will search to check if he found a solution....
Sent from my iPad using Tapatalk HD
slimfire is offline   Reply With Quote
Old 05-23-2015, 10:32 AM   #6
Wheel speed ok with 15/87, but just tested for 5 min and temp of motor and esc was approx 40 degree Celsius
Esc is brand new hh BLE pro
Old 05-23-2015, 01:11 PM   #7
I joined the Band!
I'd recommend the full size 540 too, a 44mm motor is just going to be weak and you'll be constantly looking for more power in Wraith. If the HH motors are out of stock look into the Tekin ROC412 or Pro4.
Although the HH Puller Pro 3500 and Trailmaster Pro 3300 540's seem to be in stock at Holmes right now.
Eric0424 is offline   Reply With Quote
Old 05-23-2015, 01:19 PM   #8
I have the Trailmaster Pro 540 3300kv right now and I'm not very happy with it. I'm looking for something that will be more smooth on the bottom end.
Old 06-19-2015, 10:31 AM   #9
Did you ever find a solution for this?
I had the same trailmaster pro motor in my scx10 and the low end is not that great simply because its a 2-pole motor. If you get a roc412 or the new HH puller it'll be significantly better. I sold mine and got a roc412 and it was a world of difference in the crawl/low-end smoothness.
As for a revolver in a wraith i have no answer for that but 2000kv is roughly 30t and the initial videos of the revolver are in a wraith and are hauling butt. I have the revolver 540 and the stubby and they are incredibly smooth, they are in scx10 based rigs though. I do not see them not having the torque needed for a wraith and you can gear them pretty high and still have smooth low end. Just need to get a HH BLE esc one of these days to get rid of the dreaded outrunner motor chatter.
Shinjari is offline   Reply With Quote
Old 06-19-2015, 11:25 AM   #10
No I never did. I'm debating getting the new Holmes puller 540 4 pole.
Old 06-19-2015, 11:39 AM   #11
I had my stubby in my wraith for a day. 2000 kv means you have to gear it a bit high or run 4S to get wheel speed, and as a 520 it gets a bit warm. that motor is soooo supple and controllable I like it better in a scaler/trail rig.
Angus_Beef is offline   Reply With Quote
Revolver S stubby in a wraith? - Similar Threads
HH Revolver S Stubby issues infodragon Electronics 35 04-02-2015 06:09 AM
