05-22-2015, 07:41 AM | #1 |
Pebble Pounder Join Date: Jun 2006 Location: newark
| high kv motor gearing question
i would like to say thank you for any help ahead of time . I see alot of guys running above 4000 kv what do you do for gearing ? Also do you go out for 4 to 5 hrs or just ten min at a time? This is my first wraith but not crawler , i have a tekin rs and a 7.5t thunder power sensored motor laying around that i was thinking about trying in this truck but when our group goes out its for hrs . I dont want to have to stop all the time because of temp .
05-22-2015, 10:10 AM | #2 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: high kv motor gearing question
I ran a 4600kv 4 pole for a while, geared 64/11. 64t barely clears the front wraith length MIP output. 3200mah 3s lasted 40 minutes or so. Same battery is still going strong well over an hour at 3100kv. I had problems overheating the sidewinder 3 ESC without a fan, didn't have issues after adding a fan. You will break lots of parts, wraiths don't like 25mph. And carry a backpack full of batteries. Or just get a more reasonable kv motor and don't worry about it. |
05-22-2015, 10:30 AM | #3 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
I have no problems running a 4000kv motor. Haven't broken anything major. I use my truck for a trail / crawler truck. My ESC is a MMP. Motor is a HobbyWing 4000kv 3656sd sensored motor. Gearing is 60/12 I run mostly 3s batteries. 3700mah will last me for about 2-3 hours trail running. The 3700mah 3s will last about the same for me as a 6000mah 2s. The only concern I have about that motor is it appears to be a 2 pole. Depending on your rig weight, a 2 pole might get a bit warm. Gear is low to start and check temps. Last edited by robertjpjr; 05-22-2015 at 10:32 AM. |
05-23-2015, 05:39 AM | #4 |
| Re: high kv motor gearing question |
high kv motor gearing question - Similar Threads | ||||
Noob motor and gearing question . | Wizardman | Newbie General | 5 | 10-31-2013 05:46 PM |
Scx10 gearing and motor question | jayuk022002 | Axial SCX-10 | 1 | 12-28-2011 11:06 AM |
20t motor and 45t motor gearing question? | rcstrike | Newbie General | 1 | 11-16-2011 03:40 PM |
Motor/Gearing question? | JDeezie82 | Electronics | 7 | 03-04-2011 06:29 AM |
Maxx gearing/motor question | eric113 | Newbie General | 0 | 02-09-2007 10:44 AM |
