05-25-2015, 05:49 PM | #1 |
Newbie Join Date: May 2015 Location: The Couve
| Wraith Spawn
UPDATED WITH CHANGED LIST SOFAR Alright I'm a newbie and sorry if I'm posting in the wrong area.. I was just about to drop some coin on purchasing a Spawn kit. I have not had electric in awhile and been out of the rc game. I tried doing some searching but my Google Foo is failing me. So anyways to the questions and specs of what I might buy. Specs: Spawn kit Roc412 Tekin Mamba Max Pro ESC Futaba 3PM-X 3-Channel FASST System Duratrax Onyx LiPo 3S 11.1V 5000mAh 35C Proline bronco body Hitec HS-5645MG Digital Ultra-Torque Metal Gear 2BB Axial dig upgrade Questions: Will all of that run together for the time being? I know the gearbox and drive shafts will eventually need upgraded but for now would stuff survive? Is there anything you would change and why. That's all I can think of for now thanks for reading hope to read some helpful answers soon. Last edited by Jdlucasjr; 05-26-2015 at 05:40 PM. |
05-25-2015, 06:01 PM | #2 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: Wraith Spawn
To get the maximum control out of the brushless system, it would be best to pair up a sensored ESC with that Tekin sensored motor. What are the plans for a servo? Make sure to connect a Castle BEC to the servo to get the full amount of power to your servo and to save your other electronics. |
05-25-2015, 06:04 PM | #3 |
Rock Crawler Join Date: Oct 2006 Location: New Tripoli, PA
| Re: Wraith Spawn
First off welcome to the forums, Spawn kit----- Futaba------ As far as the electronics, I am not familiar with the ones you stated so I will hand that over to someone else. But I can answer the battery question, I personally run the turnigy brand batteries from Hobbyking, and I know a bunch on here run them also. You will spend less on these and they are just as good. Or you can even look into valuehobby for your batteries, much cheaper then the name brand stuff and as stated just as good. Cheers, Wade Last edited by Wade; 05-25-2015 at 06:07 PM. |
05-25-2015, 06:12 PM | #4 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: Wraith Spawn
The Tekin SC4x motor is a 550, it's too long for the Wraith (66mm) without some modifications. You need a 540 (Pro4, ROC412, Reedy 544) for a drop in fit. I have several Onyx LiPo's (2S and 3S) and have had excellent service from them, most are over two years old and are still performing/charging/balancing as they did new. The Spawn has some durability upgrades over the other Wraith versions. How long it will last will depend on how hard you beat on it. |
05-25-2015, 06:17 PM | #5 | |
| Re: Wraith Spawn Quote:
And as far as the servo I was looking at the high tech or however they spell it with the metal internal. Do you have one to recommend? Last edited by Jdlucasjr; 05-25-2015 at 06:19 PM. | |
05-25-2015, 06:20 PM | #6 | |
I will have to look into those thank you. | |
05-25-2015, 06:23 PM | #7 | |
Good to hear about the batts I have no experience with lipo as I came from nitro trucks and before that was a old grasshopper. As far as how hard I'll beat it I have no idea lol I just want something to tinker with and take with me camping when I can't take my 1:1 out crawling (to drunk or already broke something lol) | |
05-25-2015, 06:40 PM | #8 | |
Quarry Creeper Join Date: Aug 2014 Location: Mission viejo
A Mamba max pro is what most (and myself) would reccomend. Great value, and has all the power you need. The axial vanguard esc will not be able to run a sensored motor properly. I wouldn't run a 3s, 5000mah pack. Way too big and heavy. I run a 3s 2200-2600 pack and it saves on weight while still getting more than enough runtime. The wraith kit has a lot of noteworthy upgrades. I just built mine. The driveshafts should hold up perfectly fine, the plastic transmission gears will also probably hold up for the time being. The steering and bec would be where I'd look first Check out Harley's budget build on youtube for ideas, a lot of the steps you can skip because our trucks already come with a lot of the upgrades If you're looking to save some money on the castle ESC you can even use the Traxxas funny car esc which is internally a Mamba Max pro, just limited via software. This will require some software reflashing but in the end will save you around $60 (what I'm running right now) Last edited by SoCal Crawlr; 05-25-2015 at 06:45 PM. | |
05-25-2015, 06:43 PM | #9 | |
Is the mamba waterproof? | |
05-25-2015, 06:49 PM | #10 | |
edit: Harley's motor thread hasn't really been updated in a few years (before the roc412 was actually released) so if you want some more up to date wraith opinions check out the build series on youtube. My yeti runs that pro4 HD on 3s and is very quick, the roc412 (3100kv) isn't quiet as powerful but is a shorter can (will fit the wraith no mods) and is also designed for a bit smoother startup, which you'd really appreciate when slow crawing in the rocks. But again, all comes down to what you'd like to do. The 412 just seems like an excellent all around choice. The mamba is not waterproofed. If you're looking for waterproofed holmes sells a waterproofed version of the mamba. Again, you can see the versatility of the Mamba Max pro... waterproofing on your own is always an option | |
05-25-2015, 07:09 PM | #11 | |
Was just doing some reading on the reedy motors what would be a better kv 4300 or 4800? And because I am a lipo newb would a 3s be alright behind any of the motors mentioned? I can't seem to find the pro4 Last edited by Jdlucasjr; 05-25-2015 at 07:11 PM. | |
05-25-2015, 07:44 PM | #12 | |
https://www.youtube.com/watch?v=sYu-0H1r-zo If money is the issue, the holmes stubby brushless motors are another option. I wouldn't get a reedy, but between those two the 4300. Even that is too high. You'd want something in the 3000-3500 range. The roc412 is a 3100 and perfect. As far as 3s it would be fine if the Kv is low enough. Don't want to be pushing the motor too hard. Keep in mind the wraith is quiet a bit different platform than the yeti or your friends short course trucks. The wraith is hard to control at speed, and so aiming for top end with a wraith isn't really ideal. The key with the wraith in my mind is compromise. Having super smooth low speed startup for the rocks while still having enough wheel speed to keep things interesting | |
05-25-2015, 07:49 PM | #13 |
Rock Crawler Join Date: Jan 2004 Location: Round Rock, TX
| Re: Wraith Spawn
To the OP, if you're going to edit the first post, at least let everyone know what's changed. I was getting ready to call out Lentsnh2012 for not knowing the the MMP is a sensored ESC.
05-25-2015, 07:50 PM | #14 |
| Re: Wraith Spawn
Just remembered the Reedy 544 doesn't drop below 4300kV, a little high for a crawler and are not be 3S rated. The LRP Dynamic 10's are 4-pole 540's rated for 3S, they have a 3800kV that would be good for a Wraith. The Tekin Pro4 3300 and ROC 3100 are also great 4-pole 540's and both are 3S rated. Avoid the stubby motors, at 44mm long there's not much motor for a Wraith. You'll be better off with the full length 540 (53-54mm) or a short 550 (55-56mm). Last edited by Eric0424; 05-25-2015 at 07:57 PM. |
05-25-2015, 08:05 PM | #15 |
Rock Stacker Join Date: Mar 2015 Location: NC
| Re: Wraith Spawn
I would agree that a 3s 5000 is a little big. I am building my Kit now and that is the battery I had on hand, so that is what I am using. It will fit up front but it will rub the hood a little and was tricky to locate the straps to hold it in place. When it wears out, I will be looking for a 2-3k mah battery. Like others suggest, look at a Holmes Hubbies H2O proofed ESC and their new BL motor that can be H2O proofed. |
05-25-2015, 08:48 PM | #16 |
| Re: Wraith Spawn
And don't forget with lipo you will need a lipo compatible charger. Also as others stated if you are set on brushless the roc412 is the way to go. Cheers, Wade Last edited by Wade; 05-25-2015 at 08:51 PM. |
05-26-2015, 09:38 AM | #17 |
| Re: Wraith Spawn
Thanks for the help sofar guys. So you have turned me towards the mamba esc. But what about the tekin rsx? The motor is really the only thing left for my equation it seems like. Money isn't really that big if a deal at the moment but was looking at tower hobbies where I have purchased higher priced stuff though them on there easy pay plan. 130 for a motor isn't to rediculous specially spreading it out over 3 months. I can change from a 3s it's just something my neighbor said would be good he runs them in his systems that I know nothing about. Last edited by Jdlucasjr; 05-26-2015 at 10:58 AM. |
05-26-2015, 11:29 AM | #18 |
Rock Stacker Join Date: Mar 2012 Location: SoCal
| Re: Wraith Spawn
Castle Mamba Max Pro ESC w/ CastleLink Programming Tekin Pro4 sensored And perhaps make an investment and go for the Hitec 7950 servo since you'll be turning 2.2 tires? |
05-26-2015, 01:36 PM | #19 |
| Re: Wraith Spawn You can still run 3S you just need a lower capacity pack, the 5000mAh is too thick for the stock rear mounted batter tray. The 3S 4000mAh 25c packs from Duratrax fit without a problem.
05-26-2015, 02:41 PM | #20 | |
| Wraith Spawn Quote:
Takin also makes a great esc but at almost double the price, the mamba max seems to be the more common option as it certainly has more than enough to power these trucks. The roc412 is right around $150, plus the tower hobbies discount code, and then you can break that number up into 3. So less than $50 a month is what I paid, I did it the same way. By the way the pro4 and the roc412 are essentially the same motor. Only difference being is that the sensor board on the 412 is designed for better low end startup and the motor shaft size is also tapered at the end for the use of smaller pinions. The pro4 HD is a different size all together and will not work Sent from my iPhone using Tapatalk Last edited by SoCal Crawlr; 05-26-2015 at 02:43 PM. | |
Wraith Spawn - Similar Threads | ||||
Wraith run #028 - Wraith Spawn with Little Joe | JoeConti | Videos! | 0 | 02-01-2015 11:55 AM |
New wraith spawn | desertdude | Axial Wraith | 2 | 01-17-2015 06:34 AM |
Wraith Spawn | HD Duramax | Newbie General | 7 | 01-14-2015 01:34 AM |
Wraith posion spyder or wraith spawn | Mikael | Axial Wraith | 12 | 11-25-2014 01:00 PM |
