05-29-2015, 06:29 PM | #1 |
Newbie Join Date: Mar 2015 Location: Brisbane, Aus.
| Mip's seem a little short?
I'm building a wraith... Have installed full bombproof VP scx10 transmission... Have 6mm SS outputs... Have extended yoke on axle ends... The MIP's seem a little short almost 1/2" of spline visible with suspension extended... and still about 1/4" of spline visible when compressed... Front and rear are exactly the same. Am I on the right track? or have got something wrong? photo with suspension extended...... |
05-29-2015, 06:38 PM | #2 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
| Re: Mip's seem a little short?
That's how they normally sit I thought the same thing when I got them. But after a year of hammering on them and they have held up fine.
05-29-2015, 06:39 PM | #3 |
RCC Addict Join Date: Oct 2012 Location: Norcal
The Wraith trans is wider "output to output" than a SCX10 trans. SS Exclusive's might help. "Exclusive" MIP X-Duty CVD™ Bone - Super Shafty They say that a 1/4" is enough, I usually want less than half the splines showing. Last edited by Norton; 05-29-2015 at 06:42 PM. |
05-29-2015, 07:26 PM | #4 | ||
| Re: Mip's seem a little short? Quote:
05-31-2015, 11:41 PM | #5 |
Quarry Creeper Join Date: Dec 2010 Location: Anaheim
Your driveshaft angle isn't all that great if you put a jato rod end on one end of the upper links it will fix the angle and will also pull more of the male shaft into the female shaft.
05-31-2015, 11:47 PM | #6 |
Rock Crawler Join Date: Feb 2014 Location: ?
The female end is only broached about 1/2" deep. It might look bad but in fact the most engagement you will get is about 1/2" of spline no matter where it rides.
05-31-2015, 11:54 PM | #7 |
I will post a pick with the shaft broached all the way my rig has the entire spline inside the female side. I have a super shafty exclusive on the front and its designed to ride all the way inside and I have been building my own custom yeti setup for the rear before the yeti was even released. Maybe that was the old style but the new stuff the female shaft is hollow and broached the hole way.
06-01-2015, 01:14 AM | #8 |
| Re: Mip's seem a little short? Last edited by mrhobby100; 06-01-2015 at 01:23 AM. |
06-01-2015, 01:20 AM | #9 |
| Re: Mip's seem a little short? |
Mip's seem a little short? - Similar Threads | ||||
DNA dig with MIP shafts on an SWX. Where do I buy the short MIP's | -WHEELMAN- | Axial AX-10 Scorpion | 5 | 01-31-2009 10:08 PM |
MIP's are here! | Hellbilly | Axial AX-10 Scorpion | 107 | 07-07-2008 07:53 AM |
