05-31-2015, 01:45 PM | #1 |
Pebble Pounder Join Date: Oct 2006 Location: Montreal
| Rear shock access?
The upper mounting bolts for the rear shocks on the wraith are really hard to get to because of the cage/body. has anyone done a mod to facilitate access? Any tips/tricks?
05-31-2015, 01:54 PM | #2 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
| Re: Rear shock access?
The cage flexes a good amount just push it up or down a bit until you can get your hex driver in there...
05-31-2015, 02:26 PM | #3 |
Newbie Join Date: Mar 2015
Flip the whole rear upper shock mount it puts the screws above body and cage
05-31-2015, 02:34 PM | #4 |
I took the body panel off and it wasn't so bad. Still, I've ordered these: TowerHobbies.com | Traxxas Set Grub Screws 3x25mm T-Maxx 2.5 ( I will replace the stock screws with these and then use a lock nut to hold the shock on. This way I can use a flat wrench on the inside of the fender to get them off easily. |
06-03-2015, 01:48 AM | #5 |
Newbie Join Date: Dec 2014 Location: Sydney
It is what it is, you'll need to either remove body panels or flip the top mount as suggested to make it easier.
Rear shock access? - Similar Threads | ||||
Rear Shock Brace? | lowandslow | Axial Wraith | 13 | 03-23-2013 11:54 AM |
Rear shock length? | tedo | Vaterra Twin Hammers | 3 | 03-20-2013 01:00 AM |
Rear Shock Mounts? | Grumpster1980 | Tamiya XC/CC01 | 26 | 02-19-2010 11:25 PM |
Venom Rear Shock??? | snwchris | Venom Creeper | 3 | 09-23-2009 10:30 AM |
