06-02-2015, 09:50 AM | #1 |
Pebble Pounder Join Date: May 2006 Location: willows
| Drivetrain questions
Will a wraith chassis work with ax10 axles and trans? Would it be worth doing? Thanks for any help |
06-02-2015, 05:19 PM | #2 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: Drivetrain questions
You're asking if Wraith axles (part # AX80069) will fit on a Wraith. The transmission appears to be the same as the SCX10, it too will fit. It doesn't have the provisions for the Dig unit and stock it had an 87 tooth spur, but it should bolt up. You may need a longer outdrive or driveshaft yoke for the Wraith so the rear driveshaft clears the skidplate.
06-02-2015, 09:12 PM | #3 |
I was asking if scx10 axles would fit on a wraith chassis.
06-02-2015, 09:34 PM | #4 |
yes they will, they form the basis of a 1.9 wraith
06-02-2015, 09:54 PM | #5 |
| Re: Drivetrain questions Pretty sure this >> "Will a wraith chassis work with ax10 axles and trans?" << is what you asked. I could check again but I'm almost positive you asked about the AX10 axles. Unfortunately we can only respond to what has been posted even if it contains spelling errors, typos, keystroke errors or just a general lack of knowledge. Since "ax10" was in your post you got the answer to the question asked. Had you asked if "scx10 axles would fit" a Wraith, I would have given you a different answer that referenced the 1.9 Wraith. |
06-02-2015, 10:05 PM | #6 | |
| Re: Drivetrain questions Quote:
06-02-2015, 11:18 PM | #7 |
Auto correct changed what I typed. I thought scx10 and ax10 axles were the same but I've got a lot to learn still. Thanks for the info
06-02-2015, 11:35 PM | #8 |
| Re: Drivetrain questions I've fallen victim to the auto correct myself, it can be a sneaky little devil. The spell checker in e-mail and word processing programs can be just as mischievous.
Drivetrain questions - Similar Threads | ||||
Help with Drivetrain! | Reaper09 | Large Scale Rigs | 6 | 05-01-2011 12:31 PM |
Berg Questions issues and drivetrain | toy4crawlin | EnRoute Berg | 13 | 10-01-2008 08:52 PM |
drivetrain problem | wojin | Axial AX-10 Scorpion | 18 | 08-17-2008 01:20 AM |
drivetrain help | supersonic | Newbie General | 1 | 10-24-2006 06:10 PM |
drivetrain materials | JohnRobHolmes | Chit Chat | 7 | 10-25-2005 06:06 PM |
