06-07-2015, 09:08 PM | #1 |
Rock Stacker Join Date: Jun 2015 Location: ventura
| Shock consensus
Looking to upgrade shocks mine keep leaking I've tried rebuilding a few times but to no avail. I probably messed something up in the beginning....but anyways looking for the general consensus on which would be best for crawling usage and sizes. Also what's the scoop on the droop kits I've seen out there?
06-08-2015, 05:26 AM | #2 |
Pebble Pounder Join Date: May 2013 Location: kinzers
| Re: Shock consensus
I like my 120mm kyosho shocks I got from supershafty.com no they are not cheap but after wasting money on just about everything else available I got these and nothing compared out the box they just need installed and spring preload adjusted I used bgr products on my wraith they gave me upper mount options like the droop kits that allowed ride hight adjustment droop kits do the same |
06-08-2015, 06:44 AM | #3 |
Quarry Creeper Join Date: Feb 2012 Location: Near the IL/WI border
| Re: Shock consensus
Can't go wrong with Traxxas aluminum big bore shocks for the T/E-Maxx. Part number 4962 I believe. Perform well, look great and don't leak! Reasonably priced too, about $50.00 for a set of eight. I run Axial purple springs in front, red's in the rear. Oh, length is approximately 105mm. Hope this helps!
06-08-2015, 07:05 AM | #4 |
| Re: Shock consensus
Yes thanks for the replys guys... Advantage of running a longer shock with a droop kit, more flex yea?
06-08-2015, 09:31 AM | #5 | |
| Re: Shock consensus Quote:
for me longer shocks and med rear sway bar with a droop kit seems to crawl great and still can turn at more then a snails pace | |
06-09-2015, 10:26 PM | #6 |
| Re: Shock consensus
I love my Pro-line powerstrokes. I do mostly crawling with some random bashing here and there. I run 20 weight oil in mine and feels perfect. I bought the longer (rear) version for all four corners and have the adjusters ran all the way to the top. I might try to pick up the spring tuning kit and throw some softer springs in the rear 2. The front sags perfect with my battery forward mod but the rear stays topped out sitting static.
06-09-2015, 11:01 PM | #7 |
Pebble Pounder Join Date: Dec 2013 Location: Irvine, california
| Re: Shock consensus
another vote for pro-line slash rear shocks, pick up a spring tuning set and be done |
06-10-2015, 12:12 AM | #8 |
Newbie Join Date: Dec 2014 Location: Sydney
| Re: Shock consensus
Any thoughts on running the axial shocks upside down ? I can't see why it wouldn't work, just means if the oil level is low the piston will be in air (as opposed to oil) at full extension rather than full compression. I'm thinking they might be less vulnerable to leaking that way ? Thoughts ?
Shock consensus - Similar Threads | ||||
general consensus | minicrawlerguy530 | G-Made Sawback | 9 | 09-24-2014 08:28 AM |
Is it the general consensus that the HiTec 7950 is the way to go? | Hatersauce | Electronics | 30 | 07-09-2013 02:58 PM |
Any consensus on XR10 link angles and bends? | Vertigo | Axial XR10 | 12 | 02-27-2012 06:28 PM |
Servo Consensus | jrmbtr | Losi Micro-Rock Crawler | 21 | 04-18-2011 12:14 PM |
General Consensus ? | mkinnett1 | Tires and Wheels | 3 | 09-16-2009 06:14 AM |
