06-09-2015, 11:23 PM | #1 |
Rock Stacker Join Date: May 2015 Location: Desert
| Is this the correct way to Wire CC BEC?
I have a HobbyWing 1060 ESC. Here the way I have it wired. After hooking it up, I have no steering, servo doesnt move or make a noise, tried other servos, same thing. Throttle works, makes the normal beeping sound, hooked up another receiver and steering was working, is my receiver shot you think? |
06-09-2015, 11:50 PM | #2 |
Newbie Join Date: Dec 2014 Location: Sydney
no, for steering, servo gets plugged into the BEC with a Y harness, with the power cut from the rx to servo & relying off the power from the BEC Like this, from the Castle siteCC BEC Wiring Diagram Actually, that link is wrong. Someone will put up a diagram. This is what you need Holmes Hobbies LLC Last edited by THX_138; 11-16-2015 at 10:10 PM. Reason: Merge, posting a minute apart |
06-09-2015, 11:58 PM | #3 |
| Re: Is this the correct way to Wire CC BEC?
Wont it work this way if I dont have the y harness? I already pulled out the red wire. Cause that link you posted before is the way I have it wired, just without the direct power to steering. Last edited by raider89; 06-10-2015 at 12:01 AM. |
06-10-2015, 12:02 AM | #4 |
you're saying i should do this? |
06-10-2015, 12:05 AM | #5 |
that's it, I think the Y harness just keeps the earth all nice and common
06-10-2015, 04:26 AM | #6 |
Quarry Creeper Join Date: May 2013 Location: Knoxville
On your drawing you only have 2 wires going to the servo. Is that just a drawing mistake? The signal wire has to be connected to the receiver. Other than that it looks correct.
06-10-2015, 07:41 AM | #7 |
RCC Addict Join Date: Aug 2013 Location: Missoula
You can do it either way. I have had mine set up both ways, worked fine. Currently running it the way you drew up originally, with the BEC powering the RX and everything else normal. Both ways work. |
06-10-2015, 09:07 AM | #8 | |
| Re: Is this the correct way to Wire CC BEC? Quote:
Depending on the rig I wire it both ways. On rigs where I have have weight concerns, or for simplicity I do not use the Y harness. I plug the bec into the RX, and pull the red wire from the ESC. Works fine and the servo get's it's voltage. Just puts more volts through the RX, so if going above 6v make sure your RX has the headroom. Most of my RX's can handle 9v, so I usually do the way you showed with bec at 7.4. On rigs with multiple servo's I run the BEC's direct to the servos. | |
06-10-2015, 12:48 PM | #9 |
If i get the wire harness do it go in the steering spot
06-10-2015, 01:10 PM | #10 |
I use this. Holmes Hobbies LLC |
06-10-2015, 01:44 PM | #11 |
Yeah its just a y harness bought one for 5 bucks. Do i still plug it in steering spot on rx
06-10-2015, 02:57 PM | #12 |
The harness linked isn't just a y harness. A regular y harness will not do the same thing.
06-10-2015, 03:00 PM | #13 |
| Re: Is this the correct way to Wire CC BEC? |
06-10-2015, 10:58 PM | #14 |
Pebble Pounder Join Date: May 2011 Location: Santa Cruz, Ca.
Sorry, not trying to hijack, but I have mine setup the castle way (raider's original way). Am I getting 7.4v to the servo, or only 6v? Or do I need to do it direct to servo?
06-11-2015, 04:35 AM | #15 |
So I should not use the Y adapter, and should still unplug the red wire lol? here's what I did to the y adapter. Basically took the y adapter and made it look like the rx bypass, made the 2 reds link together, unplugged the power at the rx end, i took the white wire out of the one side also. So it only has black and red. Youre only getting 5.1 volts. You have to get a castle link and hook it to the computer and chamge voltage settings. Last edited by THX_138; 11-16-2015 at 10:12 PM. |
Is this the correct way to Wire CC BEC? - Similar Threads | ||||
Direct Wire BEC | Chip73 | Electronics | 3 | 05-03-2015 07:53 AM |
CC BEC Signal Wire | jaloos | Electronics | 6 | 10-08-2013 07:40 PM |
BEC wire | Dfl4000 | Electronics | 3 | 04-24-2013 12:36 PM |
How to wire a CC BEC? | fusebmx13 | Axial AX-10 Scorpion | 5 | 04-15-2009 04:29 PM |
Signal wire from the CC BEC do anything? | swell searcher | Electronics | 2 | 07-16-2008 04:29 PM |
