06-16-2015, 07:19 AM | #1 |
Rock Stacker Join Date: May 2015 Location: Desert
| Putting shocks together today, other options for green slime?
I was told its a must to pick up some green slime for the o rings and when putting my shocks together, my LHS doesn't carry it. Any other item that does the same thing I can pick up locally at auto store or something.
06-16-2015, 07:23 AM | #2 |
| Re: Putting shocks together today, other options for green slime?
I used Vaseline on one shock build, when I was out of green slime.
06-16-2015, 08:02 AM | #3 |
I joined the Band! Join Date: Dec 2014 Location: Earth
There is no alternative to Green Slime when it comes to prolonging the life of the seals, just use a drop of shock oil on the o-rings to help protect them during installation. Dry o-rings can rip and tear during assembly, the shock oil helps prevent that.
06-16-2015, 08:05 AM | #4 |
After doing some more research I heard Noleen SF3 GREASE is the same thing as green slime, any info in regards to that? If I cant get any shock oil is going to be the replacement for now.
06-16-2015, 08:48 AM | #5 |
The SF3 looks like it may be the similar, you may also be able to use Slick Honey, Prep-M or Judy Butter if you can't locate SF3. I've never used any of them, but from reading they seem to serve the same or similar purpose (protecting & sealing o-rings and seals).
06-16-2015, 09:12 PM | #6 |
Found team losi sells green slime lhs had some. Was called shock lube and it was green lol
Putting shocks together today, other options for green slime? - Similar Threads | ||||
Yeti shock build - green slime the O-rings? | 2-shot | Axial Yeti | 5 | 03-29-2015 11:35 AM |
Marine Grease instead of Green Slime? | solomon7 | General Crawlers | 2 | 01-13-2011 07:44 PM |
putting shocks backwards?? | chromoly77 | Newbie General | 2 | 11-29-2010 06:02 AM |
Green slime in shocks? | -K- | Axial AX-10 Scorpion | 8 | 06-16-2009 05:48 PM |
