06-18-2015, 12:20 AM | #1 |
Pebble Pounder Join Date: May 2015 Location: CLAYTON, CA
| Holmes RX Bypass and CC BEC soldering require?
Bought a Protek 170T. Got the CC BEC and upon further reading of various posts learned that a Holmes RX bypass plug would be a smart addition to this system. Using this plug is there any soldering involved when installing or is it just plug to plug? Would like to see an actual diagram of this setup if anybody has one. Thanks guys, sorry for the multiple posts but this all new territory for me. Going to Axialfest in a month and want to make this trip the best it can be with the least amount of time fixing things while I'm there. Thanks!
06-18-2015, 12:24 AM | #2 |
Quarry Creeper Join Date: May 2012 Location: Italy
| Re: Holmes RX Bypass and CC BEC soldering require?
I use it on all of my rigs, no soldering required, no unplugging red wire, that's what the bypass is meant for. I have no diagram though.... But plug it into RX, the esc and servo into the other 2 ends |
06-18-2015, 06:28 AM | #3 |
Quarry Creeper Join Date: May 2013 Location: Knoxville
The only soldering required is to solder the bec to the battery, other than that it's plug and play
06-18-2015, 08:32 AM | #4 |
Rock Stacker Join Date: May 2015 Location: Desert
If you don't wanna have the bypass shipped you can buy a y harness from LHS and make it into a bypass harness.
06-18-2015, 11:29 AM | #5 |
Thanks Guys!!!!
06-19-2015, 09:09 AM | #6 |
So there is soldering involved or there isn't? Not a big deal just curious.
06-19-2015, 09:27 AM | #7 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: Holmes RX Bypass and CC BEC soldering require? |
06-19-2015, 09:37 AM | #8 |
06-19-2015, 10:02 AM | #9 |
You will need to solder in your BEC to get it powered, but otherwise there is none when using the RX bypass adapter.
06-19-2015, 10:18 AM | #10 |
| Re: Holmes RX Bypass and CC BEC soldering require? BEC gets soldered to batt. connection at ESC? Is there a diagram someone may have so a dummy like myself can see how it should all look when done properly |
06-19-2015, 10:23 AM | #11 |
Quarry Creeper Join Date: May 2010 Location: scotland
i used red jst connectors to connect my bec to my battery lead`s then another one on the bec istself so i can quickly remove it
Holmes RX Bypass and CC BEC soldering require? - Similar Threads | ||||
Holmes rx bypass clarification | Gomiband | Electronics | 3 | 02-20-2015 07:41 PM |
Holmes Hobby Rx Bypass question | Ohio_Danimal | Electronics | 4 | 02-06-2015 10:46 PM |
Castle BEC, Holmes RX bypass not working | MIcrawler | Electronics | 4 | 01-07-2015 06:51 PM |
Using Holmes Rx bypass adapter | Orph3o | Electronics | 2 | 05-09-2012 07:37 PM |
