06-27-2015, 09:27 AM | #1 |
Newbie Join Date: Jun 2015 Location: etters
| gearing help
i am new to rock crawling and rock racing i have a axial wraith rtr with stock electronics what gearing setup is good for rock crawling and is good setup for rock racing any help would good thinks dave
06-27-2015, 09:48 AM | #2 |
Rock Stacker Join Date: Mar 2015 Location: NC
| Re: gearing help
i'm fairly new to this truck as well so I won't be much help. But it would help others if you list what type of motor, speed control and battery you have. I have to assume you have the RTR Wraith with stock electronics? Gearing will be much different from a stock motor to a brushless system. Also if you have changed out your stock gears for 32p gears etc. Give a little more info and others that are in the know can give you more accurate answers |
06-27-2015, 10:46 AM | #3 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
If you don't have buy a digital temperature gun. Gear your rc to temperature 160f max! When your first starting out check your battery temperature esc and motor. Esc should be less than 120 the majority of the time. Check out the temp every 5 minutes until you finish a pack under 160f with your driving style /conditions etc. If it's to hot lower you pinion 2 teeth and drive again.
06-27-2015, 10:49 AM | #4 |
| Re: gearing help
think u for your help
06-28-2015, 12:58 PM | #5 |
| Re: gearing help
56/12 runs good with a 2s battery. I had this setup before switching to brushless.
06-28-2015, 01:20 PM | #6 |
| Re: gearing help
Also forgot to mention- check out the sticky concerning motors and gearing. A lot of good help there from Harley and others.
06-30-2015, 07:30 PM | #7 |
Newbie Join Date: Mar 2015 Location: youngsville
| Re: gearing help
Temp gun is a good idea I am going to try that
06-30-2015, 07:47 PM | #8 |
| Re: gearing help
There on sale at Harbor freight this week
gearing help - Similar Threads | ||||
Gearing | Wines77 | Axial Yeti | 7 | 10-04-2014 04:47 PM |
gearing | mr stroudy | Newbie General | 2 | 07-02-2011 02:50 AM |
gearing over/under | lifted_xj | Formula Offroad | 11 | 05-31-2011 10:44 AM |
Gearing ! | Lexar | Axial SCX-10 | 0 | 02-27-2011 01:57 AM |
gearing | Losi man | Losi Mini-Rock Crawler | 1 | 10-03-2009 09:08 PM |
