Thread: Wraith with yeti guts
Old 07-28-2015, 11:53 AM   #1
Default Wraith with yeti guts
I'm attempting to put a yeti stock motor into my wraith. So after a little nip and tucks the motor is in. But I'm noticing that a stock yeti spur gear is to big with the standard wraith set up. Am I going to have to change the whole inside? And if so (and it kind of looks that way) can I get some recommendations on how to go about this? thanks for any help.
Cork is offline   Reply With Quote
Old 07-28-2015, 05:00 PM   #2
Default Re: Wraith with yeti guts
Get a smaller spur gear?
tacocat is offline   Reply With Quote
Old 07-28-2015, 10:29 PM   #3
Yeti spur case is a lot bigger than wraith. 60 tooth is as big as you can fit in a wraith with spur cover
trig n tahoe is offline   Reply With Quote
Old 07-30-2015, 11:25 AM   #4
I have a smaller spur coming, will see how it fits. I guess I'm curious how big this snow ball is going to get. And if there is a set up out there already for something like this.
Wraith with yeti guts - Similar Threads
Swaping servo guts robertjpjr Electronics 1 05-05-2015 07:22 PM
Wraith Guts in an SCX Axle? Help..! Big Tex Axial SCX-10 7 10-15-2012 12:52 PM
Guts - Glory - Rata's Ram Rataplan Scale Videos! 0 08-14-2012 03:21 AM
Goat Guts! SteelHead Tamiya Txt-1 and Juggernaut 1 08-22-2004 10:23 AM
