07-31-2015, 10:48 PM | #1 |
Newbie Join Date: Jun 2011 Location: bakersfield
| servo question what would be a better servo for my wraith? hitec 645 mg ultra high torque metal gear bb servo, or the savox sw-0231 water proof high torque std digital servo? |
07-31-2015, 10:55 PM | #2 |
| Re: servo question
Both are weak for a wraith.
08-01-2015, 12:44 AM | #3 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: servo question
Not the best choices for a Wraith, but 200 oz-in ran fine on mine (Tactic TSX55).
08-02-2015, 08:53 AM | #4 |
| Re: servo question
Ok so which do you recommend?
08-02-2015, 09:07 AM | #5 |
Pebble Pounder Join Date: Dec 2012 Location: Vancouver
| Re: servo question
Hitec 7954sh. I've been abusing mine for over 3 years,no problems. Plenty of nuts. |
08-02-2015, 09:10 AM | #6 |
| Re: servo question
I like the Protek 150t but based on your choice I doubt that you want to pay the price for one. But it's the smoothest quiet4st servo I've used.
08-02-2015, 09:12 AM | #7 |
| Re: servo question
My first choice would be the Hitec HS-7950TH. 486 oz/in of torque and titanium gears. A little less of a budget buster is the HS-7954SH. I have used one in a wraith for a couple of years now without a problem. You will need a external BEC for running 3S or power direct from battery if running 2S. I use a external BEC so I can switch between 3S and 2S. |
08-02-2015, 10:00 AM | #8 |
Rock Stacker Join Date: Feb 2014 Location: peoria
| Re: servo question
Get a castle bec and a savox 1230 and youll have no more problems. The savox is ~80$ the bec is ~24$ and if you have a friend with the newer castle field link then your all set. Just need to set the bec for 6v i think stock is 5.4v |
08-02-2015, 10:26 AM | #9 |
| Re: servo question It depends on your ESC and/or external BEC set-up as well as what you want to spend. If you're not using an eternal BEC, then the 200 oz-in Savox above, Graupner 707 or Tactic TSX55 would be fine in your price range. If you're using an external BEC or high current internal BEC in your ESC, then something in the 300-400 oz-in would be better but the price will increase along with speed and torque. |
08-02-2015, 10:38 AM | #10 |
Rock Crawler Join Date: Nov 2014 Location: Grimcity, On
| Re: servo question
Heyok makes plug and play becs, adjustable through a pot. Wraiths on 2.2s need torque. I ran a 220oz for one run after the stocker crapped out. Now I have a hh in there set at like 500oz. Night and day, the servo is so strong, it actually moves the whole truck Sent from my Nexus 5 using Tapatalk |
08-02-2015, 11:31 AM | #11 |
| Re: servo question
im running a traxxas xl5 esc out of a stampede, im not looking to run a bec. Im just looking for a decent servo with good torque and good speed with metal gears and bearings. what do you guys think of the Tactic tsx55 servo?
08-02-2015, 11:41 AM | #12 |
| Re: servo question why not a bec? the xl5 has no drag brake, are you just running this as a basher or are you crawling with it? the tactic tsx55 is fine in my scx10 rigs but under powered in my wraith....
08-02-2015, 11:56 AM | #13 | |
| Re: servo question Quote:
I think it's well worth the $23 I gave for it. | |
08-02-2015, 02:12 PM | #14 |
| Re: servo question
Well the xl5 is what i have at the moment. id like to get another axial esc later on. I think im gonna go with the tactic 55 servo.
08-03-2015, 06:55 AM | #15 |
| Re: servo question
I recommend a Tower Pro 968 from Locked Up. Very strong servo for $33 and quite well made. Tower Pro Digital MG968 servo Too bad they are currently out of stock. |
08-03-2015, 11:48 AM | #16 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
| Re: servo question
I have a Savox 0231 in my SCX10 which is about the same torque as the Tactic 55. The 200oz/ in is (in my taste) just barely enough to turn my 1.9 BFGs. I honestly dont think thats enough torque for a Wraith. Look for something closer to 300oz/in at least and you'll be happy you spent the extra money. I have a Hitec 7954 in my Wraith and love it but there are cheaper options out there...
08-03-2015, 12:24 PM | #17 |
Newbie Join Date: Jun 2015 Location: Right their !!!!
| Re: servo question
If you have the funds, my option would be a hitec 7950, some think its overkill but too much in some situations is better than not enough . lol
08-03-2015, 01:43 PM | #18 |
| Re: servo question
my vote goes towards servo's having 400 oz/in torque or more
08-03-2015, 03:38 PM | #19 |
Newbie Join Date: Mar 2015
| Re: servo question
I have a 5645 hitec and it works fine Sent from my iPhone using Tapatalk |
08-03-2015, 04:05 PM | #20 | |
The TSX55 should be fine until he's ready to upgrade the ESC and/or add an external BEC. They may not have the torque to slam the steering lock-to-lock sitting on the ground, but they have enough to turn them lock-to-lock sitting still. | |
servo question - Similar Threads | ||||
hitec servo glitching and a servo horn question | m1009cucv | Electronics | 5 | 08-18-2012 11:22 AM |
Servo question | brainleak | Axial AX-10 Scorpion | 9 | 07-13-2011 02:04 PM |
servo question | muddigger123 | Electronics | 4 | 03-06-2011 07:10 PM |
Servo question | HaSharetz | Electronics | 6 | 08-20-2008 09:06 AM |
servo question | Wicked_Jester | Electronics | 4 | 06-11-2006 04:35 PM |
