08-03-2015, 11:49 AM | #1 |
| Testing Interest - Compact Front Shock Mounts for the Wraith
Just checking to see how many people might be interested in these. I made them for my 1.9 Wraith to get the shocks stood up, and to get the ride height level after flipping the rear chassis mount. Just something small, clean, and simple. No cutting of the hood necessary. If enough people are interested I'll do a run of them. |
08-03-2015, 11:53 AM | #2 |
Rock Crawler Join Date: Sep 2011 Location: truckee
| Re: Testing Interest - Compact Front Shock Mounts for the Wraith
I'm in.
08-03-2015, 02:58 PM | #3 |
Pebble Pounder Join Date: Apr 2015 Location: canada
I just built a set myself. I had to chamfer the bottom screw hole as the shock would hit the screw head. I made a set for the rear as well to get the shock a little up and forward. I did not flip the rear The front is lowered about 14mm and the rear about 15mm. No changes to hood. |
08-04-2015, 01:39 AM | #4 |
Quarry Creeper Join Date: Dec 2011 Location: Willows
Thats a cool design, but the problem im running into with my 1.9 wraith is panhard issues with the shocks in the stock positions. Either hitting the chassis or the axle with 100mm shocks
08-04-2015, 09:05 AM | #5 |
| Re: Testing Interest - Compact Front Shock Mounts for the Wraith Shim the shocks out at the top, and move them to the outside of the bracket on the axle.
08-05-2015, 08:41 AM | #6 |
Quarry Creeper Join Date: Dec 2014 Location: Tulsa
I'd be interested.
08-05-2015, 06:45 PM | #7 |
Actually i might be interested in these. How much would they be?
08-05-2015, 07:00 PM | #8 |
I can't talk $ in feeler threads, but they'll probably run about a Hamilton.
08-06-2015, 01:28 PM | #9 |
RCC Addict Join Date: Aug 2007 Location: Seattle
In. Thanks.
08-08-2015, 10:00 AM | #10 |
| Re: Testing Interest - Compact Front Shock Mounts for the Wraith |
08-08-2015, 10:35 AM | #11 |
Ordered, thanks. Nice job on the wraith combo pack!!
08-09-2015, 01:49 AM | #12 |
Here in a couple weeks when i get some extra moolah ill get a set of these and a set of some lower link risers
08-09-2015, 10:37 AM | #13 |
Installed on my 2.2 Wraith, using GMade 103mm shocks all around. Minor shimming required to keep things clear. Installed on my 1.9 Wraith, using 95mm Ofna shocks. No shimming due to the built in standoffs. |
08-09-2015, 11:42 AM | #14 |
can they be mounted to have the shock mounted towards the rear? I'm guessing they can be.
08-09-2015, 11:48 AM | #15 |
It really depends on the size of the shocks and the length of the wheelbase you're running because the chassis tube above the stock locations will be in the way. The mount will physically fit either direction.
08-09-2015, 12:05 PM | #16 |
Mines a 1.9 wraith so pretty short and I'm running the vaterra ascender aluminum shocks.
08-09-2015, 12:23 PM | #17 |
On my 1.9 the shocks bump the cage when they are towards the back. Ofna shocks are kinda on the skinny side. But really, the whole idea of these is to move them forward, not backward.
08-09-2015, 12:50 PM | #18 | |
| Re: Testing Interest - Compact Front Shock Mounts for the Wraith Quote:
I'm currently building a 1.9 wraith. | |
08-09-2015, 12:57 PM | #19 |
Ahh okay guess I'll have to get a set and see.
08-09-2015, 01:03 PM | #20 |
When the shocks are excessively angled in towards the chassis, the spring and oil rates progressively get weaker the further the suspension cycles up.
Testing Interest - Compact Front Shock Mounts for the Wraith - Similar Threads | ||||
Significant play in the front shock mounts | fidelity101 | Axial Yeti XL | 3 | 04-10-2015 07:51 PM |
Strengthening Rear Shock Mounts After Moving Battery Up Front | Brickman | Axial Wraith | 9 | 02-01-2015 05:56 PM |
Speedweigand Customs Wraith front shock mounts | Speedweigand | Scale parts | 1 | 09-07-2012 04:28 PM |
New GH Front Shock Mounts | GravelDuster | Axial Wraith | 3 | 07-06-2012 11:41 AM |
Front Shock Mounts | Land Crab | Axial Wraith | 7 | 01-27-2012 12:09 PM |
