08-14-2015, 03:52 PM | #1 |
Newbie Join Date: Jul 2015 Location: Delavan
| Servo location ?
Is it better to mount the servo in the chassis or on top of the axle . Setting my wraith up for rock crawling and was just wondering wich location is better . Thanks .
08-14-2015, 04:03 PM | #2 |
| Re: Servo location ?
Chassis mounted servos are for scale looks only. Axle mounted performs better and doesn't require a panhard bar.
08-14-2015, 04:24 PM | #3 |
Rock Crawler Join Date: Nov 2014 Location: Grimcity, On
If your panhard isn't setup correct it causes bumpsteer. I use 4 link on my rigs. Easy and effective, if you start needing sorca points you can attack other parts. Sent from my Nexus 5 using Tapatalk |
08-14-2015, 05:00 PM | #4 |
I joined the Band! Join Date: Dec 2014 Location: Earth
The chassis mounted servos are more trouble than they're worth. If you're not looking to gain any scale points or to hide your servo on the chassis, then it's waste of time and expense. The axle mount is less complicated and performs better.
Servo location ? - Similar Threads | ||||
Servo winch mount location | novarider | Axial SCX-10 | 6 | 04-01-2015 10:27 PM |
unortodox dig servo location | BigSki | Axial AX-10 Scorpion | 7 | 01-06-2011 02:30 PM |
Steering Servo Location.... | Tydl | Axial AX-10 Scorpion | 1 | 01-20-2009 06:23 AM |
Alternative steering servo location | AYKBOBCAT | Tamiya Txt-1 and Juggernaut | 12 | 03-20-2006 04:19 AM |
remote location servo | cborrowman | Electronics | 1 | 03-08-2005 04:27 AM |
