08-31-2015, 03:41 PM | #1 |
Pebble Pounder Join Date: Apr 2013 Location: SoCal
| Need a new servo
Hi I have a Savox SA-1230. It is starting to fade, and I need to replace it. Can't decide if I should run the same servo or if anyone has a better option. This one is crazy loud. |
08-31-2015, 05:34 PM | #2 |
| Re: Need a new servo
Hitec 7950
08-31-2015, 07:35 PM | #3 |
Why do you recommend that one? It's less torque with more volts? Sent from my iPhone using Tapatalk |
08-31-2015, 07:50 PM | #4 |
[QUOTE=blarouche;5288988]Why do you recommend that one? It's less torque with more volts? Sent from my iPhone using Tapatalk[/QUOTE Because they will last a long time and hitec is great about repairing them. The one in my Wraith is going on 3+ years and still going strong. |
09-01-2015, 01:48 AM | #5 |
Solar D772 if a budget value servo nets any consideration $ 22.00 is a lot cheaper then an hitec 7950 will set ya back slightly less torque @ 417 oz/in... but probably enough for most. ^ D772 needs be powered @ 7.4v for max potential the 7950 yields 69 more oz/in for torque @ 7.4v but that servo will cost four times as much dolla' Only draw back... Hobby partz does not supply nor support the D772 repairs. So basically ya purchase a couple... and just swap out to another if one might fail. Repair costs of the high dollar servo's... seems excessive anyways. jmo I've gotten two years crawler use outta my D772 so far... tho' it's currently steering my SCX-10. Mine has proven to be purdy durable/reliable... Not bad at all if considering it's cost. so I'll be putting one in my Wraith/Nylint 1/6 conversion as well. compare specs for yourself... Solar Servo D772 High Voltage 0.17sec@7.4v 64g Digital Metal Gear HS-7950TH High Voltage, Ultra Torque, Titanium Gear, Coreless Ultra Premium Servo | HITEC RCD USA I'd recommend running an external/volt adjustable bec for either. |
09-01-2015, 06:15 AM | #6 |
Pebble Pounder Join Date: May 2015 Location: CLAYTON, CA
Protek 170T. Ultra fast and tons of torque. 600+in. oz.
09-01-2015, 07:15 AM | #7 |
Quarry Creeper Join Date: Jun 2015 Location: Athol, Massachusetts
You cant always go by the specs they list. A good servo is never cheap but a cheap servo can work imo to sum it up buy what you can afford but dont cry if it breaks its just money hitec awesome, i do have a MKS DS1220 thats cheaper and works good too. look at speed also i hate slow servos
09-01-2015, 04:49 PM | #8 |
I'm considering the Savox SB-2230SG Dimensions(mm): 40.3x20.2x45.0 Weight(g): 84.0 Speed(@6.0V sec/60): .16 Torque(@6.0V oz-in): 499.9 Speed(@7.4V sec/60): .13 Torque(@7.4V oz-in): 583.3 Gear: Unique Steel Bearing: 2BB Case: Full Aluminum 25 Tooth Spline Frequency: 250-333hz Pulse Width Frequency: 1520 I may have to get the solar just to try out in my scx10. |
09-01-2015, 10:46 PM | #9 |
Newbie Join Date: Nov 2012 Location: Vancouver
I got the hitec 7950 because I was getting sick of replacing the servo every second outing, just to have it break anytime a friend touched the controller. Since going with the 7950 I have had no issues going on over a year (knock on wood now) and would get it for my next truck in a heart beat.
09-01-2015, 10:58 PM | #10 |
What truck are you running the 7950 in? Sent from my iPhone using Tapatalk |
Need a new servo - Similar Threads | ||||
C.I. - Servo Guard - Servo Clamp - Servo Mount - Annoucement | Nova's Ark | Crawler Innovations | 10 | 05-07-2015 01:25 PM |
***Crawler Innovations Engraved Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** | Nova's Ark | General Crawlers | 106 | 10-20-2013 02:16 AM |
***Crawler Innovations Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** | Nova's Ark | General Crawlers | 228 | 07-12-2011 01:17 PM |
***Crawler Innovations Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** | Nova's Ark | General Crawlers | 266 | 04-01-2011 02:18 PM |
Crawler Innovations Servo Guard - Servo Clamp - Servo Mount GIVEAWAY!!! | Nova's Ark | General Crawlers | 219 | 10-18-2010 12:43 PM |
