09-02-2015, 09:50 AM | #1 |
Quarry Creeper Join Date: Aug 2014 Location: Indy
| Help me nail down my pinion spur combo
OK so I have settled on my motor esc combo and need advise on whats going to give me the coolest temps and best run time. I went with the MMP and roc412 3100 and will only run 2s packs. I'm not looking for speed runs or anything like that. Just crawling and a little but of trail stuff. I know the AX2 is 4:1 from the factory. Is this going to be ok? I am not sure of the weight of the rig but its got full VP axles and links. gmade piggyback shocks and stock body. Overall my main goal is cool temps and long run times. Thanks |
09-02-2015, 10:05 AM | #2 |
Pebble Pounder Join Date: Apr 2015 Location: canada
| Re: Help me nail down my pinion spur combo
can you post your current gearing for the diff and spur?
09-02-2015, 10:09 AM | #3 |
12 pinion 56 spur - 32pitch gives you a decent trail crawler change to 3 cell and it will lift the front tires |
09-02-2015, 10:28 AM | #4 |
| Re: Help me nail down my pinion spur combo |
09-02-2015, 10:39 AM | #5 |
Pebble Pounder Join Date: Jul 2015 Location: Fort Collins
I am running overdrive/underdrive in the axles on a tekin pro4 3300kv with MMP. the gearing I am running is 56/14 and on 2s its perfect....on 3s it rips the front tires off the ground and has bad torque twist when you punch it. You can always adjust punch control on the MMP but it slows reaction time down when crawling. On 2s the 56/14 seems to be pretty good. If you arent running HD gears in the diffs I would suggest it. The brushless even on 2s seems to eat stock gears. just a suggestion!
09-02-2015, 11:00 AM | #6 |
mr rick is right check your motor temp. anything from 12 to 15 will work for you. try the stock 12 if you have the kit. - this is for 2 cell at 3 cell you will want a 12 - 14 max - unless you start upgrading gears and such. |
09-02-2015, 11:33 AM | #7 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
Ud f/r for best gear mesh 56/12 or 56/11 is very common I have that system in a rig & thats what i use without motor gettin warm!!! |
09-02-2015, 01:54 PM | #8 |
So what is the 15/60 combo going to do starting out? Will I have temp issues crawling and trailing?
09-02-2015, 03:45 PM | #9 |
start with the 15 and see if the motor gets hot. should be a great crawler! |
09-02-2015, 07:44 PM | #10 |
Pebble Pounder Join Date: Dec 2012 Location: Vancouver
I have the same esc and motor set on my wraith and have 56/12 gearing running 3s. No heat problems and crawls smooth. I am very happy with this combination. I mostly crawl with some trailing and the occasional burst of full throttle to get up over obstacles.
09-03-2015, 06:37 AM | #11 |
Quarry Creeper Join Date: Jun 2015 Location: Athol, Massachusetts
spur (56)/ pinion (12) = 4.66 so 60/15=4 4 to 5 is a good spot for cool temps the closer to 5 the better |
09-03-2015, 10:55 AM | #12 |
All I could get was 54/11 and thats 4.90 Should that get me going? |
09-03-2015, 11:48 AM | #13 |
yes that is fine. 12/60 is the same thing if your already have either or |
09-03-2015, 03:32 PM | #14 |
Well 54/11 was a no go. Too small to get proper mesh so I went 56/11. That's 5.09 and hope it will work. I'll probably order a 12t pinion.
09-06-2015, 10:42 AM | #15 |
Just wanted to thank all that helped. I got it running last night and I'm happy as can be. Plenty of torque and speed for my needs. Motor stayed very cool.
Help me nail down my pinion spur combo - Similar Threads | ||||
Which spur/pinion combo is best? | Talont | General Crawlers | 8 | 04-11-2014 12:11 AM |
what spur and pinion combo for my rig | Mariano | General Crawlers | 1 | 12-14-2012 05:51 PM |
Pinion/Spur combo with 2.2's | Planespotter | Axial SCX-10 | 2 | 07-24-2010 01:31 AM |
4.5bl w/emaxx 3908 pinion and spur combo | DirtBall | Tamiya Txt-1 and Juggernaut | 0 | 01-27-2010 09:07 PM |
Spur pinion combo?? | Lvninprds | Newbie General | 6 | 03-31-2006 11:10 AM |
