Thread: 1.9 Wraith-TJ build
Old 09-04-2015, 02:08 AM   #1
Default 1.9 Wraith-TJ build
Started a 1.9 Wraith build with the spar-parts i had laying around...
Some of the ingredients:
AX10 tranny with VP Hurtz dig
Trackstar 13.5 sensored brushless motor
AX10 Axles stock gearing, front with narrow XR10 steering mod.
Turnigy 959 alloy servo on axle
Castle MMP
Turnigy BEC 6V 3-5A
AX10 Shocks semi-droop?
Proline TSL XL on axial 8-hole with custom beadlock rings
HPI TJ lexan body
Made a new bracket to suport a mini-servo for the dig:
tomster is offline   Reply With Quote
Old 09-04-2015, 05:41 AM   #2
Default Re: 1.9 Wraith-TJ build
The body is biggest work...
But i really like how this looks!
i mounted the rearend with some links i had laying around, but the are too long, i will move the axle a few mm forward.
Shock options is the next problem.
i have 4 brandnew Proline powerstroke SCX 90mm shocks but the seem to be too short....
in the pics i tried AX10 shox half droop they seem to be right in length but not scale...
Old 09-05-2015, 01:31 AM   #3
Almost a roller!
I went back to the proline 90mm shocks and like the ride hight.
But i dont think thi is the final setup... might try some 100mm shocks!
Old 09-08-2015, 02:11 PM   #4
painted the body and made some rocker-guards:
Old 09-14-2015, 08:45 AM   #5
Mounted the SSD D60 axle case in the rear:
Old 09-15-2015, 02:51 PM   #6
Mounted the new front axlee housing:
Got steering?
Mounted the hood with some mini-hinges, will ad 2 nyodeme magnets to fix it in the front
Old 09-28-2015, 12:35 PM   #7
New grill out of lexan (test fit!)
Stickers for the 3racing winch:
Got the axles finished with all the links and Mip shaft in front, Traxxas out rear:
Old 10-07-2015, 05:08 AM   #8
Grill and lights are in!
Currie Rock crawler Bumper in the works!
Old 10-13-2015, 01:03 AM   #9
Bumper & winch are mounted, i will create a new winchplate ones i have the new fairled.
Old 11-14-2015, 10:37 AM   #10
Finally some update....
First attempt on a rear swaybar:
Old 11-15-2015, 09:25 AM   #11
The recycling continous ! Used some old Axial shafts to connect the swaybar arms to the axle.
Gesendet von meinem GT-I9295 mit Tapatalk
Old 11-15-2015, 09:29 AM   #12
The Interior fits, installed some cheap seats from Dinky RC to save some weight.
Sunk the winch flat to the bumper, now it looks scale!
Old 12-02-2015, 02:36 PM   #13
Tomorrow i will try it on the rocks!
Old 12-03-2015, 06:35 AM   #14
On the rocks!
Old 12-03-2015, 06:48 AM   #15
Are you having any binding issues with your steering links flipped?
NWHavok is offline   Reply With Quote
Old 12-07-2015, 02:52 AM   #16
No, steering works great! I use XR10 knuckles and c's. together with Wraith plates.
Anyone know about a 3D printed TJ grill or another way to make a grill more TJ likish?
Old 12-07-2015, 05:54 AM   #17
Build looks great. How did your sway bar work?
Fantastic pictures of your area..
TAT76 is offline   Reply With Quote
Old 01-11-2016, 02:07 PM   #18
Sorry for the late answere...
The rig handles great, it dosnt have much travel but at the other side its realy stable.
Now we have snow and my playground is frozen up... but i want to test it more and also wirhout the swaybar to see the difference.
1.9 Wraith-TJ build - Similar Threads
1.9 wraith build or scx10 build? Cork Newbie General 13 06-08-2015 08:17 AM
My wraith build. cg78 Axial Wraith 7 02-26-2013 10:35 PM
