09-11-2015, 11:13 AM | #1 |
Quarry Creeper Join Date: Aug 2014 Location: Indy
| HD Wraith gears
Does it batter what side they go on? I thought about flipping mine so my VP covers would be right side up but want to make sure.
09-11-2015, 12:40 PM | #2 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: HD Wraith gears
If you flip the diff over the axles/tires will spin in the opposite direction.
09-11-2015, 12:58 PM | #3 |
| Re: HD Wraith gears |
09-11-2015, 02:18 PM | #4 |
Quarry Creeper Join Date: Jun 2015 Location: Athol, Massachusetts
| Re: HD Wraith gears
Both ways work just make sure both are on opposite sides and reverse your motor if need be.
09-11-2015, 02:24 PM | #5 |
Rock Crawler Join Date: Jan 2007 Location: Viroqua
| Re: HD Wraith gears
Easier way to remember when assembling ar60 type axles, pumpkins on driver side, if the wheels rotates the wrong way, just flip only the bevel gear 180% until both axles rotates the same direction. That's it. |
09-11-2015, 03:09 PM | #6 |
| Re: HD Wraith gears
HD gears are sprial cut. I was asking if they should be on one side over the other because if that.
09-11-2015, 03:47 PM | #7 |
RCC Addict Join Date: Aug 2013 Location: Missoula
09-11-2015, 04:20 PM | #8 |
09-11-2015, 04:51 PM | #9 |
| Re: HD Wraith gears
They are run both ways in the real world, a LP dana 44 front runs on the coast side. HP rears do as well. Running on the coast side is considered to be weaker, but the weight/size/power/shock load doesn't exactly translate to RCs. Both diffs on my wraith are running that way, I've wrecked axles/lockers/housings/bearings/everything else and haven't killed either set of HD gears. I would set them up on the drive side if possible, but it doesn't seem to really matter. Last edited by maslin; 09-11-2015 at 04:54 PM. |
09-11-2015, 04:59 PM | #10 |
| Re: HD Wraith gears Yes, just install as normal. The spiral cut doesn't matter, they're still the same type of gears (ring and pinion). Sorry I didn't answer sooner, I stepped out for a "minute" and it turned into a couple of hours. Last edited by Eric0424; 09-12-2015 at 09:12 AM. |
09-11-2015, 05:13 PM | #11 |
Rock Crawler Join Date: Sep 2009 Location: Bloomsburg, pa
| Re: HD Wraith gears i think i understand what you are asking. it doesnt matter which way it makes the tires turn as long as both axles are spinning the tires in the same direction. If its going in reverse when it should be going forward you just switch the polarity on the motor to spin it the other way. |
09-11-2015, 08:28 PM | #12 | |
| Re: HD Wraith gears Quote:
I never thought about that. You make a good point. | |
09-11-2015, 09:13 PM | #13 |
| Re: HD Wraith gears
the instr. manual places the ring gear as such... looking down... front axle = passenger side rear axle = driver side I'm not sure if matters which way the center chunk's cover is positioned. but again... the instr. manual shows... cover logo = positioned opposing the ring gear Frt/Rr |
09-11-2015, 10:02 PM | #14 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| Re: HD Wraith gears
When I built my first Wraith kit I had the ring gears in the wrong way and it just sat in the same spot full throttle and all four wheel spinning, not moving forward or would not move in reverse either then I flipped the ring gear in the rear axle and that fixed the problem and it worked like it was supposed too Last edited by kgb424; 09-11-2015 at 10:06 PM. |
