12-30-2015, 02:31 PM | #21 |
RCC Addict Join Date: Nov 2011 Location: cold state
| Re: Sourdough U4RC
Cool design! Thumbs up
12-30-2015, 04:22 PM | #22 | |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
| Re: Sourdough U4RC Quote:
Then the LCC drive shaft Part Number LOSB3580 and LCC drive cup Part Number LOSB3581 | |
12-30-2015, 04:25 PM | #23 | ||
Thank you! | ||
12-30-2015, 09:23 PM | #24 | |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
Are you planning on doing anything with the plate wheels to help keep dirt out? | |
12-30-2015, 11:06 PM | #25 | |
But I have thought about a large ring of thin polycarb tubing to help keep debris out. | |
12-31-2015, 05:39 PM | #26 |
| Re: Sourdough U4RC |
01-01-2016, 09:13 PM | #27 |
Rock Stacker Join Date: Dec 2015 Location: Cincy
| Re: Sourdough U4RC
Wow. I need to build a truck like this next.
01-01-2016, 09:49 PM | #28 |
| Re: Sourdough U4RC
Great looking car!
01-08-2016, 04:10 PM | #29 |
Rock Crawler Join Date: Jan 2008 Location: P-TOWN
| Re: Sourdough U4RC
Rig is looking way sweet! Wow those axles are beefy, and whats the final measurement form hex to hex with that full width set? Thanks. |
01-08-2016, 04:47 PM | #30 |
Pebble Pounder Join Date: Jul 2013 Location: El Centro
| Re: Sourdough U4RC
So with that kit, only the rear axle is widened? I don't know if it's just me or if that front axle seems wider than normal as well. Great looking rig by the way. -Corrupt |
02-06-2016, 10:44 AM | #31 | ||
| Re: Sourdough U4RC You should, it's been a lot of fun building! This one actually is probably going to be for sale soon. Thanks! Still working on finishing it up. Quote:
And thank you! I really like how this truck is looking! | ||
02-06-2016, 10:50 AM | #32 |
| Re: Sourdough U4RC
I am having a tough time trying to figure out where to mount the electronics. So I would appreciate your guys' input. Keep in mind the chassis is already coated, so the parts need to bolt around the tubes with a clamp/brakcet, or zip ties. Here is a picture of my thoughts so far: Battery up front on a CF plate with velcro and a strap. Then reciever box in the back between the shocks. And ESC inside somewhere. I think I'm going to pick up a Wraith or Yeti interior to fill out the rest of the body as well. Not sure how the Wraith one will fit with the 2spd trans servo. |
02-06-2016, 11:13 AM | #33 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
| Re: Sourdough U4RC
I'll give a few hundro's for this and you wouldn't have to decide where all that goes. Just saying.
02-06-2016, 05:00 PM | #34 |
Quarry Creeper Join Date: Dec 2015 Location: ossipee
| Re: Sourdough U4RC
Im in the same boat as you with the electronics looking forward to see what you come up with
02-09-2016, 10:05 AM | #35 |
| Re: Sourdough U4RC
I counter sunk the screw on the front servo plate to make everything clear nicely. I also picked up another set of the proline power strokes for the front end. I'm picking up stainless front tubes inserts and that should finish all the chassis work. So the only thing left will be electronics and lexan interior/fender wells to finish out the look. |
02-12-2016, 01:30 PM | #36 |
02-13-2016, 11:22 PM | #37 |
| Re: Sourdough U4RC
Since I couldn't get a trailing arm set up that I liked to work, this truck kind of changed direction from my original plans. Figured I would give an updated parts list! Chassis: UCFab Wraith platform Ceramic coated clear Body panels from Proline F-150 for Yeti Proline Power stroke shocks 6063-01 Axial Sway bar kit (narrowed) AX30782 Stock Wraith Skid AX80079 Vanquish Products Wraith Link kit 3/16" RC4WD AX2 transmission (soon to be lexan interior) Axles: (Front) HPI Bevel gears A856 and A857 Holmes Hobbies 7075 Spool LNC/TH hybrid drive shaft Axial Universals AX30780 Vanquish Products black Chubs and Knuckles BeefUpRc Stainless Steel axle tubes Y-Town Carbon Fiber LP servo/upper link mount Vanquish 3/16" Ti steering links Axial aluminum hex's AX30429 Vanquish Products SLW hubs .475" Vanquish Products SLW V4 wheel, 1" width, black with Raw beadlock rings Fast Eddy Bearings (Rear) Axial Underdrive Gears AX30402 Holmes Hobbies 7075 Spool LNC/TH hybrid drive shaft Axial Yeti rear axle kit AX31290 Vanquish Products SLW hubs .225" Vanquish Products SLW V4 wheel, 1" width, black with Raw beadlock rings Fast Eddy Bearings Tires: Pitbull Growlers CI Double Duece Foams (narrow) Electronics: Hitec 7950 Servo with Robotronic horn Unknown shift servo Holmes Hobbies TrailMaster BLE Pro (waterproof) Holmes Hobbies Puller Pro BL 540 Standard 2200kv (waterproof) Castle BEC Tactic 3CH 2.4ghz radio/reciever Turnigy 2200mah 3S 40C lipo's |
02-14-2016, 12:07 AM | #38 |
| Re: Sourdough U4RC
I'll be interested if you can wear in the lockers with such a rig. Such a sweet rig!
02-14-2016, 06:30 AM | #39 |
| Re: Sourdough U4RC
Nice build keep it going!!
02-14-2016, 09:34 AM | #40 |
| Re: Sourdough U4RC
How do you like the axial sway bar you used? Did you have to mod it to fit
Sourdough U4RC - Similar Threads | ||||
Sourdough Twin Hammers | sourdojack | Vaterra Twin Hammers | 21 | 04-22-2014 10:51 AM |
U4rc | BoulderDan | Arizona | 3 | 11-24-2013 10:51 AM |
Sourdough GC-3A | sourdojack | Axial AX-10 Scorpion | 120 | 10-04-2011 10:41 PM |
Sourdough Losi | sourdojack | Team Losi Comp Crawler | 23 | 01-10-2011 01:01 PM |
