09-18-2015, 03:07 PM | #1 |
Newbie Join Date: May 2014 Location: Twin Cities
| Axial transmission binds
I stripped a gear in my tranny, so replaced both plastic gears with gear set AX80010. When I turn the gears by hand there is obvious binding at one, maybe two spots. I can see no problems with the gears themselves. Any suggestions to solve the binding would be appreciated. Thanks.
09-18-2015, 03:28 PM | #2 |
Newbie Join Date: Jan 2015 Location: Oklahoma
| Re: Axial transmission binds
When you put the shafts back together with the screws the shafts aren't perfectly aligned. I noticed this when I replaced mine with the Axial steel gears. I had to chuck one end of this in my lathe or drill and fiddle with it to get them trued up. There's enough slop in the holes you have to get it centered or it will bind. Not for sure there all this way but sure was on mine.
09-19-2015, 03:34 AM | #3 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
I have 2 suggestions, First it is possible to either have a piece of plastic flash still on the main gear under the output or to have not tightened the 3 screws evenly, both of which will have the outputs running slightly out of true. 2nd, and I think this is unlikely because I figure you've re-used the stock screws, but I once assembled a spare trans & the M2 screws I grabbed for the main gear had a very slightly larger head than the stock Axial, not so large they didn't fit but just large enough to distort the plastic gear slightly & induce a slight bind, only worked it out by opening the case & seeing the bind aligned with the screw. |
09-19-2015, 12:10 PM | #4 |
I joined the Band! Join Date: Dec 2014 Location: Earth
Triple check all three gears to make sure there's not a small chunk of the broken teeth in them. It only takes a small chip from a broken tooth to bind the transmission. I had the same centering issues mentioned with my Wraith and SCX10, I had a couple of small shafts and some spacers lying around that I used to keep the diff halves and diff gear centered. |
09-19-2015, 03:56 PM | #5 |
Eric, that is exactly what the problem was. A small shaving from the plastic idler gear was found between the teeth of the metal input gear.
09-19-2015, 11:27 PM | #6 |
| Re: Axial transmission binds It's a common problem when transmission gears get stripped, I usually scrub the case and all the internal parts clean before reassembly. Just in case there's a little something I may have missed.
Axial transmission binds - Similar Threads | ||||
Binds up/no power.... | KBR97 | Losi Micro-Rock Crawler | 6 | 06-17-2014 06:38 AM |
truck controlles itself when steering binds, why | mudd_slinger | Electronics | 2 | 03-05-2012 07:58 AM |
It official.. Mine binds too (big shocker) | ericinMD | Losi Micro-Rock Crawler | 3 | 02-21-2010 07:39 PM |
motor smokes when binds? | Tklan Crawler | Electronics | 5 | 01-01-2010 12:37 AM |
