09-23-2015, 01:09 PM | #1 |
Newbie Join Date: Sep 2015 Location: Leeds UK
| rasing ground clearance
Well iv tried a search and one of the threads that was brought back has invalid links in it. im wanting to get abit more ground clearence on my wraith. im quite handy at making things or have been on 1:1 landys RC is a new ball game for me so looking for suggestions of tried and tested to see what people have done. i know it will make it abit more top heavy, but iv also got plans for this cheers guys |
09-23-2015, 01:17 PM | #2 | |
Quarry Creeper Join Date: Aug 2014 Location: Indy
| Re: rasing ground clearance Quote:
09-23-2015, 01:25 PM | #3 |
not sure how much i want to go, hence asking what people had done. may look into longer shocks, was trying to see what could be done with standard kit though 1st |
09-23-2015, 01:26 PM | #4 |
Newbie Join Date: May 2015 Location: Goodyear
Why not just go with a taller tire?
09-23-2015, 01:32 PM | #5 |
Taller tires, tummy tuck, high clearance links, longer shocks, portal axles, the sky's the limit.
09-23-2015, 03:27 PM | #6 |
whats the tummy tuck? any info on high clearance links as this is what i was thinking. |
09-23-2015, 03:37 PM | #7 |
Newbie Join Date: May 2015 Location: Australia
Tummy tuck is when you move the skid plate from the normal rail it is bolted to up to the one above it. You then cut away the rail it was previously on and your done ! This gives you more clearance but also a tad higher centre of gravity, so balance the amount of each. Sent using Tapatalk Last edited by axialspawn; 09-23-2015 at 03:40 PM. |
09-23-2015, 03:41 PM | #8 |
I'd start here: 10107-14 Interco TSL SX Super Swamper XL 2.2" Rock Terrain Tires |
09-23-2015, 04:24 PM | #9 | |
RCC Addict Join Date: Aug 2013 Location: Missoula
09-23-2015, 06:55 PM | #10 |
currently gtot the proline chisel 2.2 fitted and have the stock tyres and wheels to one side Pro-Line Chisel 2.2 Crawler Tyres (G with Memory Foam Inserts PL1149-14 il look into the tummy took , cheers |
09-23-2015, 07:18 PM | #11 |
Titanium Mike is a vendor on here and makes high clearance links. If you get VP Ti links you can turn them 90 degrees from the way they are normally mounted and have high clearance links. You're basically looking for lower links with one or two bends in them.
09-23-2015, 07:27 PM | #12 |
| Re: rasing ground clearance Yeah, these will get you some clearance. I wonder if the Wraith wheelbase is even long enough. Lol
09-23-2015, 07:32 PM | #13 |
Quarry Creeper Join Date: Jan 2011 Location: 808 via Reno, Nv.
Since you didn't share with us on what type of build you are after, the answers are going to be vague. There are many options to go but we need to know what you are trying to achieve in order to give you a more accurate advice. If you just want it super tall and don't care about it being top heavy, than all the advice given will do it for you. If you want to avoid all the technical stuff like the tummy tuck etc and just want height, than get 130mm plus shocks and a lift kit and be done with it, but remember, balance is key. Your pinion angle is going to be incorrect, drive shaft may be at max extended length etc. Lots of bad things and poor performance is going to affect this build. Unless of course its going to be a shelf queen? Good luck! |
rasing ground clearance - Similar Threads | ||||
ground clearance | moto261 | Axial AX-10 Scorpion | 14 | 03-27-2010 06:32 PM |
Ground Clearance? | Norris | RC4WD Bully | 9 | 03-20-2010 08:35 PM |
Ground clearance | BigBoss | General Crawlers | 3 | 03-02-2010 01:59 AM |
ground clearance | yoda316 | Axial SCX-10 | 5 | 01-28-2010 12:19 AM |
Ground Clearance | Prophecy | Axial AX-10 Scorpion | 7 | 11-01-2007 08:51 PM |
