09-28-2015, 08:59 PM | #1 |
Quarry Creeper Join Date: Aug 2014 Location: Indy
| So what did we decide was the best slipper for the AX2?
I don't want to search and mine slips worse than a penguins ass on a ski slope ins 2nd. I only running a roc412 on 2s. Thought about the slash 4wd slipper but if there is something better I'm all ears
09-29-2015, 06:39 PM | #2 |
| Re: So what did we decide was the best slipper for the AX2?
So everyone is running the stock slipper?
09-29-2015, 06:50 PM | #3 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
I run the stock slipper in mine on 3s. When it starts slipping too much I clean the pads with rubbing alcohol to remove any oil, dirt and moisture. I'm geared pretty low (60:12) so that helps. When I decide it's time to upgrade I'll probably go with a Robinson Racing slipper. |
09-29-2015, 07:01 PM | #4 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
All 32p gearing I run a 60t spur from duratrax. They have a 56t as well. Or the Emaxx 58t will work as well. A 60/12 ratio is what I use. Mostly on 3s |
09-29-2015, 08:38 PM | #5 |
I'm on 32p with 56/11 and it slips like hell taking off in 2nd but hooks nice in1st. It does slip in 1st when the tires are in a real bind.
09-30-2015, 06:34 AM | #6 |
Newbie Join Date: Mar 2015
I've got a slash slipper on my from Robinson racing 32p 56t and a 13t spur on a tekin pro4 3300, I got the slipper nut tightened pretty good so it doesn't really slip at all
09-30-2015, 07:11 AM | #7 |
RCC Addict Join Date: Aug 2013 Location: Missoula
Stock slipper tightened till it stops. 3300kv trailmaster pro, 56/13, 3s and 6mm tranny/MIPs. Rides wheelies on pavement, only slips if it's really really bound.
10-08-2015, 04:02 PM | #8 | |
Quarry Creeper Join Date: Mar 2015 Location: Woodland
| Re: So what did we decide was the best slipper for the AX2? Quote:
I thought I had the nut tightened down plenty, but clearly I was wrong. | |
10-09-2015, 07:06 AM | #9 |
RCC Addict Join Date: Aug 2007 Location: Seattle
Traxxas setup on mine. Aluminum friction pads.
10-09-2015, 07:30 AM | #10 |
I ended up just using a slipper from a slash 4x4 and it's working great.
10-09-2015, 07:36 AM | #11 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
I use the 48p steel slipper from RRP made for the wraith.
So what did we decide was the best slipper for the AX2? - Similar Threads | ||||
ax2 and ..... | mcsgt98 | Axial Wraith | 10 | 06-05-2014 06:05 AM |
Slipper Pads for Gen 3 Slipper? | Markeje | Axial Wraith | 0 | 05-16-2014 09:13 AM |
10T Holmes Puller and 3s : Slipper or no slipper? | utieh | General Crawlers | 2 | 12-28-2011 07:42 AM |
