What shall I run my internal BEC at? Hi all Just bought a MMpro and tekin roc412 2300kv motor am only running 2s at the minute and only have a cheapish servo, I think it runs 13kg at 7v, so what should I set my internal bec too on my MMpro? Thanks in advance Brad |
Re: What shall I run my internal BEC at? 6v should run the RX just fine. Set the external BEC to 7v, or whatever your servo is rated to. |
Re: What shall I run my internal BEC at? You can set it to the maximum voltage of the lowest rated component. If all you components (receiver, servo(s), lights) are rated at 7v or higher, you can run 7v (maximum allowed by the MMP internal BEC). |
Re: What shall I run my internal BEC at? Thanks for your help, awesome already. Uk forum all seem very quiet!! |
