10-01-2015, 09:58 AM | #1 |
Newbie Join Date: Apr 2013 Location: UK
| MMpro and tekin 412 problem
Need help!! Just fitted my mm pro and my tekin roc412 motor, all leads connected correctly, it moved at 1st but then it didn't have revers I plugged my castle link card in and now it just makes an attempt to move forward or back but doesn't go anywhere, anyone she'd any light?? Thanks in advance |
10-01-2015, 12:58 PM | #2 |
Quarry Creeper Join Date: Aug 2014 Location: Indy
| Re: MMpro and tekin 412 problem
Did you calibrate your transmitter?
10-01-2015, 06:02 PM | #3 |
Quarry Creeper Join Date: Jan 2011 Location: 808 via Reno, Nv.
^^^^^^^What he said, just like re-binding it. If that doesn't work than check to make sure your ESC plug is correctly installed into your RX. What color lights are showing on your ESC? Are you using NIMH or LIPO batteries? If it's NIMH you may not have enough juice to power the electronics.
10-02-2015, 08:00 AM | #4 |
Rock Crawler Join Date: Mar 2013 Location: columbus
| Re: MMpro and tekin 412 problem Did u just build the truck? Have you been in the axles? |
10-03-2015, 02:58 AM | #5 |
Yes I built the truck months ago and was running a 1410 motor in it, it was fine, anyway I took the MMpro to the shop, and turns out the esc was faulty, It wasn't supplying the motor with enough current apparently, so I changed it to Tekin rs gen2. But thanks guys for all your input.
MMpro and tekin 412 problem - Similar Threads | ||||
Tekin Roc 412 problem | AngelowDoom | Electronics | 10 | 01-01-2014 02:19 PM |
Any problem with using MMPro 1 cell? | BubbaEinstein | Electronics | 1 | 12-02-2012 06:21 PM |
Tekin FXR or MMPRO? | CERO | Team Losi Comp Crawler | 18 | 04-10-2011 09:36 PM |
