12-28-2015, 01:19 PM | #21 |
Quarry Creeper Join Date: May 2014 Location: United States
| Re: instead of sighting a yeti i caught a bug (;
never got anywhere with bgr sadly.. working on building my new set of f9 axles and having a bit of an issue... the tubes wont slide all the way into the diff housing. if i pull the drop out diff section out of the housing the go all the way in but not with it installed.. not sure what to do because its like that on the front and rear. is there something im doing wrong? also the ssd scale scx10 chubs and knuckles dont fit currie f9 axles.. not happy working on getting this thing mounted up to an scx10 chassis and then mounting the wraith cage on it. that plastic just isnt sturdy enough |
12-29-2015, 09:48 AM | #22 |
Pebble Pounder Join Date: Apr 2015 Location: San Antonio
| Re: instead of sighting a yeti i caught a bug (; |
12-30-2015, 10:57 AM | #23 | |
| Re: instead of sighting a yeti i caught a bug (; Quote:
vanquish said the bearing caps are the problem with the tubes not sliding in all the way so they sent some out. great customer service, huge thanks to Vanquish products. anyways snapped the chassis blah blah blah heres my fix: and i bobbed the rear so my tires wont rub anymore Last edited by microcrawlers; 12-30-2015 at 11:00 AM. | |
12-30-2015, 07:47 PM | #24 |
Newbie Join Date: Dec 2015 Location: Palisade
looks like a nice build. looking forward to hearing more as you move forward
12-31-2015, 08:46 AM | #25 |
front shock mounts and shortened chassis im not making this c2 legal because there arent any comps where i live. steel chassis was just because i was snapping the wraith cage |
01-10-2016, 07:13 PM | #26 |
| Re: instead of sighting a yeti i caught a bug (; https://youtu.be/M5TwsJP2ojg quick video. got the new tires mounted up for the rear so now they match finally. took this video last time i went out though when i had the swampers on the rear Last edited by microcrawlers; 01-23-2016 at 09:17 AM. |
01-23-2016, 09:30 AM | #27 |
well i know all the weak points now.. vanquish sent new bearing caps because mine were machined wrong. f9 housings will be installed soon bent my upper links. the one on the bottom should look like the one on the top destroyed strc heat treated carbon steel universal Last edited by microcrawlers; 01-29-2016 at 11:51 AM. |
01-25-2016, 11:54 AM | #28 |
Quarry Creeper Join Date: May 2012 Location: Baja, Mex / Calexico, Ca.
what combo are you running currently? you are breaking parts left and right
01-25-2016, 02:32 PM | #29 |
RCC Addict Join Date: Aug 2013 Location: Missoula
Breaking known weak parts. F9 housings will fix most of that, MIPs have been pretty stout for me. All thread links with a bunch of bends aren't exactly robust... you can bend them by hand pretty easily.
01-29-2016, 08:33 AM | #30 | ||
i drive this thing pretty hard Quote:
those are all the most necessary upgrades so after i pick those up ill be focusing on either an exo or my yeti. | ||
01-29-2016, 09:31 AM | #31 |
pov i uploaded about a week ago https://youtu.be/NfmGIhY6ozU |
01-29-2016, 10:45 AM | #32 | |
Im running a 3656 sd xerun motor on 3s and havent had that many breakages but I have few upgrades already. but mostly depends on how you drive it | |
02-13-2016, 08:36 AM | #33 |
02-13-2016, 11:30 AM | #34 |
thanks to phillip hepp (a vanquish dealer) ive got some nice vanquish goodies on the way to get this thing up and running again. after all that gets installed i just need to build a metal tube chassis to replace this hacked up wraith/scx10 one |
02-13-2016, 02:03 PM | #35 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
You desperately need some beef tubes I like the size of the cage, it looks very much like the bouncer Side by sides getting built. Like this: |
02-15-2016, 04:03 PM | #36 | |
| Re: instead of sighting a yeti i caught a bug (; and theeenn somewhere along the line i ran out of money lmao Quote:
and yeah ive been told before that it looks like a rzr or side by side lol i was going for ultra4 moonbuggy type look. working on getting a welder setup so a full custom chassis will be next Last edited by microcrawlers; 02-15-2016 at 04:05 PM. | |
02-19-2016, 08:05 AM | #37 |
axle porn |
03-07-2016, 08:25 AM | #38 |
got it setup for rear steering. working on programming remote for the shift servo im using a spektrum dxe with an ar610 reciever, cc bec pro, two savox servos |
03-07-2016, 04:14 PM | #39 |
Quarry Creeper Join Date: Dec 2015 Location: United States
| Re: instead of sighting a yeti i caught a bug (; I've got one from my Wraith that looks the same, I only got about 3 minutes from it before the crunch. Went back to Axial universals front and rear. You can get grade 8 threaded rod if you want to try making your own links again. Last edited by Soldat Vaillant; 03-07-2016 at 08:49 PM. Reason: Typo |
03-07-2016, 08:15 PM | #40 | |
thanks for the recommendation | |
instead of sighting a yeti i caught a bug (; - Similar Threads | ||||
Rio grande valley yeti sighting. | 4X4 Freak | Axial Yeti | 7 | 02-08-2015 04:32 PM |
Caught The Bug ( oh no!) | SpicyMcHaggis | Axial SCX-10 | 10 | 12-12-2014 08:13 PM |
yeti sighting in the desert | puffntough760 | Videos! | 0 | 09-25-2014 03:10 PM |
Caught the bug! | Phippy | Newbie General | 9 | 05-31-2013 08:03 PM |
I've caught the Maxx bug! | gregrocks90046 | Traxxas Crawlers | 8 | 10-13-2005 07:48 PM |
