hub replacement? will this work hey guys so i stripped my pin hubs, i think that's what they are called, will OEM 1.9 or 2.2 HEX Adaptor conversion for RC4WD OEM steel wheels EASY change[1.9" Z-S0268] - rc Bitz work with the stock Wraith wheels? |
Re: hub replacement? will this work These will RC Accessories - 2.2 Beadlock Wheels - SLW Hubs ( Axial ) - Vanquish Products Axial also has a plastic hex hub for those wheels http://www.amazon.com/Axial-IFD-Hex-...axial+ifd+hubs unfortunately I believe it only comes with two of each width. |
Re: hub replacement? will this work im in the uk so kinda hard to find :( |
Re: hub replacement? will this work VP is the way to go if you want to spend the money and never worry about them again "thumbsup" For a less expensive, one-piece design, these will work: Axial Yeti Aluminium 2.2 Wheel Hub Adapters (9Mm Thickness) - 1Pair Set - GPM YT009A They're in UK to boot! |
Re: hub replacement? will this work mike i must be blind :/ where do i get them in the uk!? dont want to be stung by import tax Yet again haha |
Re: hub replacement? will this work Heh, I guess they just put UK in their name but have nothing to do with the country. I figured GPM Racing UK would be, you know, based in the UK!?! :roll: If you can't find anything similar PM me. I've got a set of Boom Racing hub adapters I'd be willing to part with in a few days if we can work out shipping. Four of the short blue ones: Boom Racing Axial Yeti Aluminum Front & Rear Wheel Hub Adapters - 2 Sets Blue BR648014 |
Re: hub replacement? will this work Hey. I'll have a look tomorrow after work. I think I still have the spares from my ps wraith. Yours for karma if I find them. Alternatively you can get axial hexes and the adaptor kit form modelsport.co.uk. It's probably worth doing this anyway as I spun the pins on my ps pretty quick. |
Re: hub replacement? will this work http://i421.photobucket.com/albums/p...psbxn8bkmm.png Cost and part numbers. This will allow you to fix your trail ready beadlocks. |
Re: hub replacement? will this work And I may be wrong but I think the rc4wd one have a different bolt spacing. |
Re: hub replacement? will this work I agree, not convince they have slw bold pattern. |
