10-26-2015, 12:32 PM | #1 |
Rock Stacker Join Date: Oct 2015 Location: Kingston, WA
| Wraith Kit Cogging Motor
Hello guys, so I picked up a wraith kit with Novak combo a couple months ago and have now become completely engulfed by the hobby. But recently I have come across the issue of my motor cogging from a dead stop to full throttle. It only does it for about a full second than goes to full speed. I have searched throughout this forum with no such luck to my exact problem. A little background info: Venom 5k mah 20c 2S lipo Novak timbuk2 ESC Novak Ballistic 13.5T sensored brushless CC BEC 10amp Savox 1230sg servo Holmes y harness Novak Glitch buster FlySky receiver for the life of me I can't figure out why it is cogging/glitching from a stand still to full throttle. Does anyone have any ideas? Thanks |
10-26-2015, 12:42 PM | #2 |
| Re: Wraith Kit Cogging Motor
Could it be because your battery has too slow of a discharge rate? All suggestions I've seen when running brushless is to have at least a 30c rating on your battery. Otherwise the ESC and motor are starved when you punch it. Just a thought.
10-26-2015, 12:53 PM | #3 |
We were running brushless on small 20C packs before the C rating wars began. His 5000 mah pack can handle it. Triple check that the sensor bits are good. |
10-26-2015, 12:53 PM | #4 |
I'll look into getting a new battery and give that a try. That really is about the only thing I haven't tried
10-26-2015, 12:55 PM | #5 | |
| Re: Wraith Kit Cogging Motor Quote:
I'll try that too, I'm also thinking too that I may need to re-solder my ESC/BEC to my Deans connecter too. Just to rule out that connection. | |
10-26-2015, 12:56 PM | #6 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
This sounds like the Tower Hobbies combo I started with! My first thought is battery as well. But if it cogs when you start up slowly, check your sensor cable real good and maybe give the contacts a good cleaning. It can be hard to get the sensor cable fully seated in the Novak motor with that rubber gasket around the port.
10-26-2015, 12:59 PM | #7 | |
It doesn't do it when I start slowly, only from a dead stop to full throttle and I did buy my from tower hobbies as well! | |
10-26-2015, 01:01 PM | #8 |
One thing I just remembered - that combo has a Hall Sensor test, it's in the manual. Run through that to make sure the motor sensors are working correctly.
10-26-2015, 01:02 PM | #9 |
| Re: Wraith Kit Cogging Motor |
10-26-2015, 01:08 PM | #10 | |
This is one of the reasons I got rid of my Novak combo - it was just too finicky. It worked great most of the time but little glitches and hiccups got me frustrated. | |
10-27-2015, 09:39 AM | #11 |
So last night I accomplished the Hall test for the sensors and it did pass. I also bought a new 30C battery as well and threw that in but it didn't cure the issue. I can only assume now that it has to do with the battery connection to the ESC. I put Deans connectors on both the ESC and battery. I think I did a good job on the battery connectors but I'm not too sure about the ESC, so hopefully tonight I can redo that connection and post my results afterwards.
10-30-2015, 11:11 AM | #12 |
Well I finally got around to completely redoing my wiring and come to find out I had a bad connection between on the ground wire between the ESC and Deans connector. Now it works like a champ. Thanks guys for all of your input. |
Wraith Kit Cogging Motor - Similar Threads | ||||
Ordering Wraith Kit - Motor Question | LuvMyTJ | Axial Wraith | 16 | 12-03-2012 06:19 PM |
What motor/esc for my Wraith Kit? | KraKenRC | Axial Wraith | 5 | 10-12-2011 11:59 AM |
MOA and motor cogging/ stall | paystin | Team Losi Comp Crawler | 90 | 09-08-2009 07:18 PM |
