10-29-2015, 08:00 PM | #1 |
Newbie Join Date: Oct 2015 Location: Chicago
| Wraith Proline Front and Rear Bumper
Hey all, So I haven't found too many ProLine Wraith Bumper write ups and especially for rear bumper. I installed mine this evening and must say gives the wraith a nicer look. Some complained about the steering servo hitting the proline provided bracket but all you have to do it flip it over and have the tabs face outward. The rear bumper was easier than I thought. I removed the factory rear tail lights from the wraith and used 3/32 drill bit and opened up the hole, I than centered the rear bumper and using just drilled holes as a guide drilled new holes into bumper and used provided taping screws from proline to secure it and worked out great. |
10-29-2015, 08:12 PM | #2 |
Quarry Creeper Join Date: Aug 2014 Location: Indy
| Re: Wraith Proline Front and Rear Bumper
Looks cool. I never knew Proline made bumper for the Wraith. Thanks for the pics.
10-29-2015, 08:25 PM | #3 |
| Re: Wraith Proline Front and Rear Bumper |
10-31-2015, 05:56 AM | #4 |
Newbie Join Date: Jul 2015 Location: Northern Illinois
Looks good. Is that the narrow or the wide? I have been looking at them too but was hesitant because it said only the front bumper fit. Good to know it's easy enough to get to work!
11-01-2015, 06:33 AM | #5 | |
| Re: Wraith Proline Front and Rear Bumper Quote:
It is pretty good. I am not the biggest fan for the two bolt from bumper system, but does well. There is someone that makes one looks very similar to this but it is aluminum, so not sure how good that one would be. | |
11-20-2015, 01:19 PM | #6 |
Rock Crawler Join Date: Nov 2004 Location: roanoke
So if I read that right your rear bumper is directly attached to the stock light locations?
11-20-2015, 03:10 PM | #7 |
Quarry Creeper Join Date: Aug 2009 Location: Gamecock Country
I had these on my wraith a while back . If you flip the mount around you'll gain about 1/4" on the front to clear your tires. That's what I did and cut the center out and super glue at the mounts to get a lot of clearance for my servo arm.
