11-08-2015, 05:08 AM | #1 |
Pebble Pounder Join Date: Aug 2014 Location: Perth Western Australia
| Marc's WertyU4 Build
Hi All, Latest build I am doing for U4RC, I built a Yeti and SCXU4 for my sons, this one is Dads rig to race. Wraith base with WertyMade U4 Rear Chassis with the following parts so far. VP Links (Front Lower/Upper & Rear Upper) UCFAB Wraith Trailing arms with Traxxas ends HR Knuckles and C-Hubs VP SLW hubs Axial HD Drive Hubs Axial UD Heavy Duty diff gears HPI Spider gear mod in front diff (1M weight diff oil) STRC Diff covers Holmes Hobbie Steel Locker in rear HR Rear Lock Outs Yeti Kit IFD Beadlocks PitBull RB2's with CI foams RR Steel gears in Transmission RR 32P Steel Spur / Slipper Kit Super Shafty "Beefy" top shaft 93mm G-Made SHocks (Front) 103mm G-Made Piggyback shocks (Rear) Hot racing Wraith Sway bar kit Hitec 7950 Servo Junfac Front Drive shaft MIP Yeti Rear Drive shaft ALTD896 Designs motor plate, Front shock mounts and front servo mount/brace Axial Deadbolt Body Axial Wraith Spawn Interior Custom Battery LCG Tray Mamba Max Pro RevTech 4XS 3800KV 4 Pole SCT motor Castle 10amp BEC Holmes BEC Harness 3S 2700mAh Battery Futaba 4PLS Radio System Mocked up the Yeti rear end for some ideas Last edited by Teenracer; 03-01-2016 at 05:13 AM. |
11-08-2015, 05:12 AM | #2 |
| Re: Marc's WertyU4 Build |
11-08-2015, 05:13 AM | #3 |
11-08-2015, 03:40 PM | #4 |
Newbie Join Date: Jul 2015 Location: Northern Illinois
How do you like those shocks. I love how they look and was thinking of picking up a set for my wraith.
11-08-2015, 05:07 PM | #5 |
Yes JDAY the RR10 in kit form would make a good base to start a build and customise to suit. Dawagner, I haven't run this rig yet but I have a set of G-made 93mm shocks on our SCXU4 and they were quality, easy to put together and perform well on the track, I am hoping these are the same once racing. |
11-08-2015, 06:22 PM | #6 |
Very cool. I really like your Werty cage. Reminds me, I need to get mine powdercoated and installed.
11-12-2015, 11:44 AM | #7 |
Rock Stacker Join Date: Mar 2014 Location: North Bay
11-12-2015, 05:49 PM | #8 |
Hi vanwraith001, Its a Wertymade U4 rear chassis, I was told there's only two made like this. Contact Matt @ Wertymade Werty Made :: Home |
11-12-2015, 06:39 PM | #9 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
Don't know about that particular design, but can check Rpp Hobby and CKRC. Werty does awesome custom work, but has a waiting list a couple months long ATM. Still worth sending him a message tho
11-12-2015, 11:14 PM | #10 |
Yes, his work is definitely worth the wait. I have a couple of his pieces and they are top notch.
11-15-2015, 04:50 PM | #11 |
11-23-2015, 08:56 PM | #12 |
Hi All, Made some progress on the WertyU4, made a front bash guard out of a Traxxas Rustler stock bumper and clocked the C-hubs back a position. Fitted up the following UCFab Wraith trailing arms MIP Yeti Driveshaft RPM Rod Ends Hot Racing Sway Bars Trinity RevTech 4XS 3800kV Motor Last edited by Teenracer; 11-23-2015 at 09:18 PM. |
11-24-2015, 01:24 AM | #13 |
Rock Crawler Join Date: Mar 2014 Location: Dallas, Texas
You will battle temps with that motor. I have one and it always runs hot no matter what gearing or load. I am talking 180 at the end of a run, but it's in a SCT that weighs 4.5 pounds on 2S. Leopard sensored motors seem much more resilient to me and I have no temp issues even though I gear more aggressively.
11-24-2015, 01:39 AM | #14 |
Thanks MeanTT, I was running it on 3S in my U4 yeti which seemed to be fine with temps, but racing heats are only ~5 minutes long, the WertyU4 is lighter and has lower gearing so hopefully last the distance for the same style racing. Cheers for the advice Marc |
11-24-2015, 07:15 AM | #15 |
Newbie Join Date: Feb 2015 Location: Portland
What is the HpI spider gear mod?
11-24-2015, 08:51 AM | #16 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: Marc's WertyU4 Build Uses hpi brand spider gears & pin in the diff cup to unlock the front end, same as a Yeti but by most reports a better gear set than the Axial. Stuff it with 1mill weight diff fluid (gel) to get an limited slip effect Last edited by altd896; 11-24-2015 at 08:25 PM. |
02-28-2016, 04:52 PM | #17 |
02-28-2016, 04:55 PM | #18 |
02-29-2016, 07:43 AM | #19 |
Quarry Creeper Join Date: Dec 2015 Location: ossipee
Nice and clean build looking forward to see how it drives
02-29-2016, 06:11 PM | #20 |
RCC Addict Join Date: Feb 2008 Location: your back yard
I really need that rear wertymade cage. Well done sir.. Sent from my SM-G900V using Tapatalk |
Marc's WertyU4 Build - Similar Threads | ||||
Marc's SCXU4 Build | Teenracer | Axial SCX-10 | 27 | 03-04-2016 07:04 PM |
Marc's Yeti Kit Build | Teenracer | Axial Yeti | 60 | 03-04-2016 07:00 PM |
Marc's XR10 "The little Tank" | Swiss Rock Force | Axial XR10 | 168 | 08-22-2014 07:02 AM |
Videos of Marc's XR10 "The little tank" with Shape Shifter Bodyless Chassis | Swiss Rock Force | Videos! | 4 | 08-26-2013 11:54 AM |
Marc's XR10 "The little Tank" | Swiss Rock Force | Videos! | 3 | 01-29-2013 01:02 PM |
