11-11-2015, 08:47 AM | #1 |
Pebble Pounder Join Date: Jul 2008 Location: Toronto
| wheel weight? how much is too much?
I just bought a spawn kit after having been away from RC for years, my point is. I built up my wheel with weights on an alloy beadlock and it weighs 530 grams which is well over a pound, is that too heavy for a wraith wheel? just looking for opinions before assembling the other three. thanks
11-11-2015, 09:18 AM | #2 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: wheel weight? how much is too much?
Yes. Remove it all and put the wheels back together. Your axles, wheel bearings and knuckles will actually stay in one piece.
11-11-2015, 09:26 AM | #3 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
Knuckle weights are the best way of adding low, front end weight that not going to kill your driveline components and bearings. Knuckle Weights | Product Categories | RcBros Hobbies |
11-11-2015, 09:34 AM | #4 |
Pebble Pounder Join Date: Mar 2013 Location: Los Angeles
The answer to that is largely personal taste, but there are a few things to keep in mind. If you built your wraith for speed at all then you don't really want lots of weight in the wheels. Heavy wheels on a high speed rig will hurt the handling and make it very difficult for the suspension to do it's job. If you are only doing slow crawling then heavy wheels can be pretty helpful depending on the terrain. However, those heavy wheels will put a lot of extra strain on the steering and drive. If you're going to run that much weight you need to make sure you have a pretty beefy servo (and bec) and if you haven't already upgraded gears, drive shafts, etc., you probably will in the not too distant future if you are heavy handed with the throttle. Although, if you drive with a little finesse and restraint even the stock drive parts should last a while. That's harder than it sounds though. Oh and I guess I'm assuming you have an aluminum servo horn. If you built it with the kit supplied plastic horn, that thing will last all of about 1/2 second (if you're lucky) with those heavy wheels.
11-11-2015, 09:46 AM | #5 |
I have alloy c's and knuckles, MIP driveshafts, a 45turn brushed handwound and this rig will be used for crawling, I haven't yet chosen a servo, but I do of course have an external bec.
11-11-2015, 10:58 AM | #6 |
Quarry Creeper Join Date: Aug 2013 Location: Wijnandsrade, NL
530 sounds a bit like the new definition of overkill imo.... 150 even should be enough i guess. The strain, the tension must be enormous with all that weight. |
11-11-2015, 11:02 AM | #7 |
Running 1 pound in each was the norm for quite a while. Then slowly it has been reduced. No denying the added grip though. |
11-11-2015, 01:35 PM | #8 |
Newbie Join Date: Sep 2015 Location: Utah County
Once upon a time... I took a bunch of spare 1:1 tire weights (used for balancing tires on real cars) and put 4 or 5 of each inside each of my tires. I did my best to keep them evenly spread, and after 5 minutes of cruising around my backyard I busted a knuckle and C-hub....it was definitely overkill, and I quickly learned that unbalanced weighted tires + almost any amount of wheelspeed = a bad combination! Ha ha, I don't know what I really expected to happen...but learned my lesson nonetheless!
11-11-2015, 02:16 PM | #9 |
I had two full wraps of tire weights around the front wheels. 7.5 ounces in each front. Never broke a Losi part. The Berg had a full pound in each front. Never broke.
11-11-2015, 02:18 PM | #10 |
any weight is too much imo. Many other ways to add weight down low.
11-12-2015, 12:11 AM | #11 |
Quarry Creeper Join Date: Jan 2011 Location: 808 via Reno, Nv.
I run 8oz. each wheel up front and 4oz. each wheel out back on my wraith with aluminum beadlocks. Never had any issues with breakage, going on 3 yrs. now. Climbs rocks like a goat and works great in comps. Its not a speed demon by all means but does great low speed rock crawling. Total weight on my wraith is just under 12lbs. |
06-24-2020, 08:27 AM | #12 |
Newbie Join Date: Nov 2019 Location: ENUMCLAW
a pound per wheel is way too much my opinion any wheel weight is not good weight because it is all rotational what you need is non-rotational weight. like beef tubes or metal axle housings metal chubs, etc. if it is rotational weight I am trying to remove it not at it
wheel weight? how much is too much? - Similar Threads | ||||
wheel weight vs knuckle or axle weight vs creative weight distribution | tech712 | Axial SCX-10 | 16 | 11-04-2014 01:04 PM |
Wheel weight vs 1:1 should scalers use wheel weight | juswin24 | 1.9 Scale Rigs | 29 | 04-08-2012 07:51 PM |
Wheel weight / axle weight advice | JeffK11 | RC4WD Bully | 6 | 03-15-2012 03:30 PM |
Wheel weight Vs Axle weight. | Simon.O. | General Crawlers | 33 | 02-15-2010 07:01 PM |
Wheel weight vs. chassis weight ratio OR spung/unsprung bias | solomon7 | Tires and Wheels | 15 | 08-02-2008 06:26 PM |
