11-16-2015, 08:18 PM | #1 |
Quarry Creeper Join Date: Oct 2014 Location: yakima
| New item from super shafty for my build
Hey guy's I'm super excited to be the first person to get this from super shafty I'm building the supershafty bomb proof transmission piece by piece for my wraith and as all of us know about the 2 piece 6mm outputs well coming soon is this solid one piece 6mm output instead of two pieces it's one solid piece so the output shaft goes thru the gear where the gear now rests on a 8mm shaft and then you put the plate and the 3 screws so where as before it was only the 3 little screws holding it together and taking all the stress now it sits in a 8mm shaft with great snug tolerance also backed up by the 3 screws the machining is A1... also i thought it was really awesome that he is including the gear with every output "thumbs up" i will put up more pics of my build as I get the rest of my items... Sent from my SM-N910V using Tapatalk Last edited by rcaholic13; 11-16-2015 at 08:23 PM. |
11-16-2015, 08:44 PM | #2 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: New item from super shafty for my build
Did someone help him draw those up...? Holmes one piece outputs have been around for a little while now. Holmes Hobbies LLC |
11-16-2015, 09:01 PM | #3 |
Couldn't tell you bud I was just lucky enough to inquire on the 6mm outputs and found out about him receiving in his new 1 piece and asked if I could get one the guy is a cool dude! Sent from my SM-N910V using Tapatalk |
11-17-2015, 01:21 AM | #4 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
Could be wrong but I think I recall seeing that Holmes makes them for SuperShafty, hence the easy adaption of the HH 5mm up to the SS 6mm output.
11-17-2015, 08:41 AM | #5 |
If it is the Holmes piece, which it is identical to, make sure you track down the front bearing. It's a goofy size, I had to order them online.
11-17-2015, 11:14 AM | #6 |
So just to clarify looks like they are made by HH for shafty Sent from my SM-N910V using Tapatalk Last edited by rcaholic13; 11-17-2015 at 11:33 AM. |
11-17-2015, 11:42 AM | #7 |
Looks that way. I just got the same output from RPP and it was listed as manufactured by HH and is identical. These guys sell a lot of each other's stuff though. BTW, this is a very nice machined piece and looks indestructible. Maslin will find out for sure.
11-17-2015, 11:49 AM | #8 | |
| Re: New item from super shafty for my build Quote:
Some day it's going to rip the pin through between the rear 6mm output and the male MIP. What used to be a hole is a 3 or 4mm slot | |
11-17-2015, 11:57 AM | #9 |
I can't wait to build this thing my wraith is begging to be finished lol Sent from my SM-N910V using Tapatalk |
11-17-2015, 12:26 PM | #10 |
| Re: New item from super shafty for my build Make sure you get that rear bearing, it's 11x6x4. The center bearing doesn't need to be changed, it rides on the big part behind the gear. Front bearing is stock as well.
11-17-2015, 12:45 PM | #11 |
Thanks maslin I appreciate the heads up Sent from my SM-N910V using Tapatalk |
New item from super shafty for my build - Similar Threads | ||||
**new item**the screw catcher standard size flat mat**new item** | Team CowRC | Tools and supplies | 4 | 03-27-2013 04:23 PM |
The best, or just your favorite, solid axles for a shafty super-class build? | Chadworkz | General Crawlers | 6 | 08-20-2009 05:42 PM |
Super Shocks- My first RC CNC item | crazyorigin | General Crawlers | 12 | 07-09-2009 11:25 PM |
