11-18-2015, 05:39 PM | #1 |
Pebble Pounder Join Date: May 2013 Location: new zealand
| Heavy Metal Wraith (real steel caged)
i was getting pretty bored with the wraith again and the lack of something with speed...so the wraith cage came off and went onto a cheap arse hobbyking 2wd sct truck (i love the wraith cage but it needs to go fast and this way it does). i started out not really sure what i was going to build just been at home and not offshore working with the oil prices i can only build so many car trailers before iget over that!!! i was going to try and get a big scale hard body and just build a chassis, then it went to building a formula offroad truck and then back to a crawler...i dont have the money to spend on expensive parts so this wont be a high dollar truck and it is in real need of new axles but they will do for now. while i know steel is going to be heavy its what i have to work with and i have my mig etc so its all there. where im at at the moment its not overly heavy as i used to run 2x big hardcase 5000+ batteries for long run time. but anyway pics of where im at... and everyone always wants the flex shots... i had the make sure i had enough room for the servo at full bump so frame rail x-member is hooped rear of the frame so far |
11-18-2015, 07:23 PM | #2 |
Rock Stacker Join Date: Aug 2008 Location: Kiowa
| Re: Heavy Metal Wraith (real steel caged)
Wow! Awesome work! Can't wait to see where this one goes...
11-18-2015, 07:55 PM | #3 |
Nice job. Better than 98% of what has been on RCC in the last year.
11-18-2015, 08:46 PM | #4 |
Thanks it's the 1st rc frame/cage ive ever done. Id really like to do it brazed or in aluminum but I don't have the gear to do it and I haven't done much work with either of them. Ill admit the shock mounts look out of place but how they are I can still drill more holes to mount shocks.
11-19-2015, 10:33 AM | #5 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
Looks stout and aggressive, I'm loving it.
11-19-2015, 01:36 PM | #6 |
im going to change the front shock towers today so will post pics of what i come up with. i dont like the size of the tires i really want something around 120-130mm OD but there isnt much in 2.2 sizes the only one i like is the rc4wd dune tire which suits what im wanting it to look like anyhow. there are heaps of 1.9's in the size i want but im unsure if they will work with my front knuckles...i think a 1.9 rim size would look better also cos 2.2 look like 20's. i cant afford to buy wheels and tires at the moment so that will have to wait until i go back to work. im also thinking it needs the likes of trailing arms with double rear shocks Last edited by skidtoy; 11-19-2015 at 04:46 PM. |
11-19-2015, 04:52 PM | #7 |
right more pics made the new front shock hoops and they look alot better, i also made a front grill for it...im a jeep guy so it suits. needs different wheels/tires but anyhow pics... im going to put some radio gear in it and try it out before i paint it to make sure i dont want to change anything then it will get a coat of black. |
11-19-2015, 06:21 PM | #8 |
RCC Addict Join Date: Jul 2008 Location: San Diego
Nice job on the cage. What kind of welder did you use?
11-19-2015, 07:46 PM | #9 |
Newbie Join Date: Nov 2015 Location: crawlorado
pardon my ignorance guys, but what type of steel are you using for the tube steel chassis? I just started in the rc crawler world, but i'm no n00b to the offroading and crawling scene. I normally build my cages out of 1.75x.120 D.O.M. and i use a RogueFab tube bender to make my bends. Obviously none of this is relevant in the rc world, but thought i'd give some background of my hobby. thanks! |
11-19-2015, 08:15 PM | #10 | |
| Re: Heavy Metal Wraith (real steel caged) Quote:
--------------------------------- Personally I think the wheels / tires you're using at the moment look scale for a jeep rock bouncer / crawler. I do like the new front shock mounts, much better than the old. | |
11-19-2015, 09:02 PM | #11 | |
as was said before what welder are you guys using? I have a hobart 110v, and a millermatic 211 | |
11-19-2015, 09:15 PM | #12 |
| Re: Heavy Metal Wraith (real steel caged) Im using a boc 180 mig. I use it for everything anything under a 180 mig is abit pointless because it doesn't have enough grunt for everyday work
11-19-2015, 09:21 PM | #13 | |
11-19-2015, 09:28 PM | #14 |
Get some shocks with some up travel too.
11-20-2015, 03:24 AM | #15 |
Yea those shocks are abit crap dont hold oil at all. They are the ones where you can run them to droop or have up travel either way they are pretty crap they are just ones I used to mock it up I might get something more scale otherwise the axial ones will do for now.
11-22-2015, 06:53 PM | #16 |
so ive been doing some body panels on and off last few days and have just put some paint on the frame so i might actually get to try it out tonight or over next couple days. pic of body panels, hood has a raised center to match the hoops all made out of auto body panel steel. ive also brought some 1.9 wheels and tires to see if they look more scale otherwise im not sure what tires i will run on it because i want something with a smaller OD than most of the 2.2 tires |
Heavy Metal Wraith (real steel caged) - Similar Threads | ||||
Best winch for a heavy metal wraith?? | BlkCherry92XJ | Axial Wraith | 3 | 09-13-2015 06:18 PM |
