12-08-2015, 03:22 PM | #1 |
Newbie Join Date: Nov 2015 Location: Cypress, Tx.
| How to change out gears on diffs.???
So I ordered my new HD front and rear differential gears I'm going with standard drive up front and underdrive in the rear. The gears should be here by tomorrow, but I have never done something like this before. Is there any tricks or hidden things that I should be aware of on how to do the swapping of the gears on the differentials? I just don't want to mess it up! Is there a video or something anywhere that I can check out, or even perhaps a really good thread on how to do this very thing swapping the gears in the differentials? Thanks! -Clint |
12-08-2015, 03:30 PM | #2 |
Rock Stacker Join Date: Oct 2015 Location: Kingston, WA
| Re: How to change out gears on diffs.??? |
12-08-2015, 03:59 PM | #3 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
Just remember which side the gear is so you put the new ones in the same way.
12-08-2015, 04:03 PM | #4 |
RCC Addict Join Date: Aug 2013 Location: Missoula
And shim the pinions. Tamiya has a nice 5mm shim assortment. Crucial step.
12-08-2015, 04:09 PM | #5 | |
Newbie Join Date: Oct 2014 Location: Pueblo
| Re: How to change out gears on diffs.??? Quote: | |
12-08-2015, 05:40 PM | #6 |
Pebble Pounder Join Date: Jun 2014 Location: MA
12-08-2015, 06:17 PM | #7 | |
Stack up the shims until you can just get the pin in. The pinion should be solid in all directions. | |
12-08-2015, 06:31 PM | #8 |
Not sure why i interpreted it that way, thanks for the clarification! I was about to switch my shims from the outside of the axle housing to the inside. I guess ill just be leaving them where they are then!
12-08-2015, 09:02 PM | #9 | |
Thanks for the info everyone! | |
12-09-2015, 05:12 AM | #10 |
Newbie Join Date: Dec 2013 Location: CFL
If you've ever built a kit before, it's easy. Just make sure you grease everything, before you close everything up. Sent from my iPhone using Tapatalk |
12-09-2015, 11:19 AM | #11 | |
Then you absolutely did the right thing by coming here and asking. I too have learned a lot from this site and hopefully it does the same for you. | |
12-09-2015, 12:57 PM | #12 | |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
12-09-2015, 01:02 PM | #13 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
12-09-2015, 01:06 PM | #14 | |
Tamiya, Ø5mm Shim Set ,(53587) | |
12-11-2015, 05:04 PM | #15 | |
12-24-2015, 11:01 PM | #16 |
Newbie Join Date: Sep 2014 Location: Lafayette
Haha, I just spent the last two nights trying to figure out why the new gears I got for my ax10 axles were grinding when even the slightest pressure was being applied. After digging around my spare parts box I found a bunch what I thought were misplaced spacers. I put one outside the housing between the bearing and shaft...was so proud of myself lol... after reading this I now realize they are shims, and I did the right thing! Didn't need shims for my wraith, though.
How to change out gears on diffs.??? - Similar Threads | ||||
what parts needed to change from locked to open diffs? | Cationmoted | Axial AX-10 Scorpion | 7 | 02-05-2011 09:42 AM |
gears for open diffs missing in ax10 kit? | izeman | Axial AX-10 Scorpion | 6 | 01-20-2010 02:28 PM |
unlock diffs and where to get gears | meancrawler | Axial AX-10 Scorpion | 3 | 05-27-2009 04:45 PM |
where to find metal ring and pinion gears(diffs) | my96on22s | General Crawlers | 13 | 01-08-2009 12:27 PM |
Torsion diffs vs. locked diffs | RCMFMaxxMan | General Crawlers | 23 | 03-16-2008 02:35 AM |
