12-22-2015, 09:52 AM | #1 |
Newbie Join Date: Nov 2015 Location: cincinnati
| What shocks are you running???
Title says it all, what are the best shocks to run for your wraith for softest suspension. Sent from my SCH-I545 using Tapatalk |
12-22-2015, 10:16 AM | #2 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
| Re: What shocks are you running???
I use 103mm gmade piggyback shocks. They have a ton of useable adjustability and the dual rate collars and springs from proline shocks fit them for more tuning. The only downside I have experienced is that they are pretty bulky (obviously) and somewhat limit placement.
12-22-2015, 11:09 AM | #3 |
Pebble Pounder Join Date: May 2013 Location: kinzers
kyosho's from supershafty.com
12-22-2015, 02:29 PM | #4 |
Pebble Pounder Join Date: Aug 2015 Location: Oklahoma
I'm running hot racing 103mm internal spring shocks. No complaint here after fixing an over dampening concern. 3 different spring choices and even with the stiffest springs its pretty soft. My rig is around 8 lbs or so though.
12-22-2015, 03:10 PM | #5 |
Rock Stacker Join Date: Jul 2015 Location: San Jose
Proline Powerstroke slash rears on all four corners. Right now I'm using the stock proline springs, but I've got the full spring kit to do some tuning with when it stops raining.
12-22-2015, 03:22 PM | #6 |
RCC Addict Join Date: Feb 2008 Location: your back yard
I've been debating on what shocks to run on my build. Liking what I read on the powerstroke rears but really like the internal sprung look. For now I'm going to rebuild the stock stopping leaks and testing different springs with pistons. Hopefully I can get something to work. |
12-22-2015, 03:40 PM | #7 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
| Re: What shocks are you running??? |
12-22-2015, 05:53 PM | #8 |
Rock Crawler Join Date: Nov 2013 Location: In the country
I have pro-lines. Anybody use boomerang products? I like the look for my when I get my bomber. J.E.C RACING |
12-22-2015, 07:27 PM | #9 |
Really liking the internal spring Sent from my SCH-I545 using Tapatalk |
12-22-2015, 10:42 PM | #10 | |
Quarry Creeper Join Date: Feb 2011 Location: Vancouver Wa, USA
| Re: What shocks are you running??? Quote:
Smitty | |
12-22-2015, 10:45 PM | #11 |
Pebble Pounder Join Date: Sep 2012 Location: Clarksville
G Made 103mm Piggybacks on mine and i really like them. I'm running mine with the 4 hole pistons and springs that come with them,and they seem to do fairly well while trailing and some mild rock crawling. The only thing is the springs are a little stiff when running the wraith on a fast run in rough terrain.
12-23-2015, 04:18 AM | #12 | |
Sent from my SCH-I545 using Tapatalk | |
12-23-2015, 06:22 AM | #13 |
| Re: What shocks are you running??? I see Boomerang all over IG and have been trying to find more on them. Very good looking and with working reservoir but I'm not sure they could handle some abuse. |
12-23-2015, 06:48 AM | #14 |
My rig is 10lbs. I have one pro-line leaking already. I'm going to try Teflon tape the threads today. But I like the looks of boomerang for a bomber. Ty J.E.C RACING |
12-23-2015, 07:39 AM | #15 |
Quarry Creeper Join Date: Jun 2014 Location: Seattle-ish
For a Bomber I would use Boomerang. But on my Wraith I use Proline Powerstrokes Slash Rears all around
12-27-2015, 07:48 AM | #16 |
Newbie Join Date: Dec 2015 Location: Pine knot
Traxxas bigbores 4" with 3 hole pistons and 30 weight oil!!! |
12-29-2015, 01:53 AM | #17 |
RCC Addict Join Date: Feb 2012 Location: UK
Traxxas plastic rear shocks all round. Stock soft Wraith springs with 30wt. You can use the stock spring retainer as the Traxxas one is a little too big for the Axial springs. Cheep and easy to fix/replace. |
12-29-2015, 06:09 PM | #18 |
Quarry Creeper Join Date: Jan 2011 Location: 808 via Reno, Nv.
| Re: What shocks are you running??? Gmade Gtransitions setup in droop for that LCG w/ 30wt oil and 3 hole pistons. Its strictly a crawler so it may not be the setup you want for your application. However it also can be set up for sprung with your option of whatever hole piston and oil you want to use. |
12-30-2015, 12:00 AM | #19 |
Quarry Creeper Join Date: Dec 2010 Location: Anaheim
RC4WD king shocks medium OD with a mix of axial and losi O-rings the rc4wd O-rings are garbage and don't fit int the shock body or tightly around the shock shaft so I went around and found some integy rebuild kits I had laying round and the O-rings worked perfect took and extra of the couple O-rings to the hobby shop and matched up some that worked. its a red fat o-ring and it fits tight around the shaft on the shock and is real snug going into the shock body seals the shocks perfectly and they work good. now they still suck to fill properly with oil and I like powerstrokes or prospec shocks until there is something better. the proline stuff just bleads really well and operate properly. but rc4wd medium od king or proline stuff they both have a good selection of quality spring rates for tuning Last edited by mrhobby100; 12-30-2015 at 12:02 AM. |
01-02-2016, 01:29 AM | #20 |
Newbie Join Date: Dec 2015 Location: Teesside
Such a choice....Ive just bought a set of Gmade XD piggyback shocks for mine so see how it goes. Thanks for everyones input so far |
What shocks are you running??? - Similar Threads | ||||
What shocks you running? | throttlejock27 | Axial Wraith | 161 | 06-06-2013 11:06 AM |
what shocks are you running? | maRRtin | Redcat Crawlers | 5 | 03-02-2012 06:26 PM |
Shocks - What has everyone tried or running? | NCT_Guy | Axial Wraith | 13 | 01-03-2012 03:37 PM |
What shocks are you running? | V3500 | Axial SCX-10 | 21 | 01-22-2011 03:15 PM |
What Shocks you running? | LeDevil | Tamiya XC/CC01 | 20 | 01-17-2010 05:27 PM |
