01-02-2016, 03:44 AM | #1 |
Newbie Join Date: Mar 2015 Location: yeovil
| ifs wraith
ok guys so i question i need 4ws on my ifs wraith it just dose not turn, would a gyro work on only the rear steering ? to try to keep the back end straight when locked to front steering? The front diff is locked |
01-05-2016, 05:45 PM | #2 |
Pebble Pounder Join Date: Oct 2015 Location: GR
| Re: ifs wraith
A gyro seems like an interesting idea, but I don't know if it will cure your problem. I think overdrive gears would be a good start, and unlocking that front diff would make a huge difference too. The main issue with a gyro is that it only activates when the car goes off center, which requires speed and sliding....and if you're going that fast, you might as well unlock the diff as you probably don't need it locked for typical crawling purposes. Eager to see what you want end up doing though...very interesting idea!
01-05-2016, 06:06 PM | #3 |
Pebble Pounder Join Date: May 2015 Location: nesbit
| Re: ifs wraith
I agree the gyro idea is interesting but I'm thinking instead of 4ws try a dig for the rear and overdrive the front and make sure your connected to a strong servo.. just a thought
ifs wraith - Similar Threads | ||||
Basket case Wraith roller to U4RC 2.2 rig. Another anti-IFS Wraith. | 89redranger | Axial Wraith | 7 | 03-30-2014 08:24 PM |
Is a IFS Wraith possible? | BigSki | Axial Wraith | 5 | 08-08-2012 08:21 PM |
