01-05-2016, 11:01 AM | #1 |
Rock Stacker Join Date: Aug 2014 Location: Columbus
| Wraith Spawn kit drivetrain upgrades?
I need help with my Wraith Spawn kit build for general bashing and trail running. I decided to go with Harley’s recommendations for the motor and ESC (Tekin roc 412 3100kv and 1/10 Mamba Max Pro ESC), so with that in mind, what upgrades should be made to the drivetrain? It’s my understanding that the latest Wraith kit includes a lot of upgrades from the previous releases and since the build guides here are several years old, the recommendations may not necessarily reflect this. Currently, my planned upgrades include: Steering linkages Upper links Vanquish Stage One Kit (C-hubs, knuckles, lockouts) With my choice of electronics and the fact this is the Spawn kit, what else should I be looking at? |
01-05-2016, 11:07 AM | #2 |
| Re: Wraith Spawn kit drivetrain upgrades?
Steel trans gears, HD axle gears, lockers
01-05-2016, 11:31 AM | #3 |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
If you plan on seeing any water, Holmes Hobbies now offers waterproof (to an extent) sensored brushless combos. I would get the axial underdrive gears front and rear (AX30402), Holmes chromoly spools, steel transmission gears (AX30708 ), and a good servo with around 500oz combined with a BEC. Last edited by sourdojack; 01-05-2016 at 01:30 PM. |
01-05-2016, 12:13 PM | #4 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
Hot racing makes the cheapest spools and they are good to go. I've been using the same motor/ESC combo on 3s for almost two years and they have held up great. Also I replaced all my trans gears with Robinson racing gears which have been trouble free as well. Also a good servo and BEC I use the castle bec and hitec 7955 servo. I'd skip the vanquish stage one kit and buy the scale chubs due to the upgraded way they clamp around the axle housing also the newer lock outs as they clamp around as well. Also you should replace all the links instead of just upper.
01-05-2016, 01:29 PM | #5 |
Why would I need to upgrade the lower links too? The kit already comes with aluminum lower links.
01-05-2016, 01:53 PM | #6 |
Its a bad design that is weak and will not slide over rocks as well as titanium or stainless.
01-05-2016, 02:22 PM | #7 |
Hmmm, maybe the question I should be asking is if there is anything new for the Wraith Spawn kit that doesn't need upgrading? Or should I just go by Harley's recommendations for previous Wraiths?
01-27-2016, 11:45 AM | #8 |
Regarding the transmission itself, is upgrading the gears to steel good enough for this electronics setup? As much as I'd like to go for a totally "bomb proof" build, I don't have the cash for it.
01-27-2016, 11:49 AM | #9 |
Yes. Steel gears alone make the trans 1000% more durable. I've run big power through one of my wraiths and everything else holds up fine. I don't like the lower links. Aluminum or not. It's the rod ends that are weak. I use traxxas Revo pushrods for the lower links. Part #5319. They are direct fit other than shaving the skid just a tad where the rod end binds since they are straight. you'll see it when you put them in. |
01-27-2016, 12:29 PM | #10 |
Regarding the differential gears: This is primarily going to be a trail rig--maybe some rock crawling, but mostly I want a vehicle to go on walks through the woods or various urban environments. Given that, should I change the gearing to under/overdrive, or keep it stock?
01-27-2016, 01:03 PM | #11 | |
Quarry Creeper Join Date: Sep 2009 Location: Las Vegas
| Re: Wraith Spawn kit drivetrain upgrades? Quote:
01-28-2016, 12:06 PM | #12 |
Great, thanks for all your advise! Time to start ordering parts.
Wraith Spawn kit drivetrain upgrades? - Similar Threads | ||||
Yeti kit or Wraith Spawn kit? | The Dark Knight | Axial Yeti | 3 | 09-25-2015 09:09 AM |
New Wraith Spawn Kit | mikl | Axial Wraith | 9 | 05-26-2015 09:02 AM |
