01-05-2016, 05:30 PM | #1 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
| Any objective benefit to the 3-link panhard kit?
My Wraith build has been stable for about a year now, and I'm happy with the way it performs, but the Vanquish 3-link panhard kit intrigues me. I could buy it and install it just for the heck of it, but relocating the servo would mess up my current scheme for weighting the front axle, so first I'd like to have some idea of whether there's actually any objective benefit to using the 3-link panhard kit. Does it improve articulation or handling vs. 4-link, or is it purely a cosmetic "scale" upgrade?
01-05-2016, 05:41 PM | #2 |
Pebble Pounder Join Date: May 2015 Location: nesbit
| Re: Any objective benefit to the 3-link panhard kit?
Purely cosmetic for the "scale look" not at all for performance!
01-05-2016, 05:42 PM | #3 |
Quarry Creeper Join Date: Dec 2015 Location: United States
it's purely cosmetic and it can sometimes limit articulation and travel
01-05-2016, 05:43 PM | #4 |
| Re: Any objective benefit to the 3-link panhard kit? |
01-05-2016, 06:09 PM | #5 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
The 3 link and panhard will help to eliminate bumpsteer with cms, so that could be considered a performance advantage. However, if the servo is on the axle a 3 link and panhard has no benefit.
01-05-2016, 06:10 PM | #6 |
Yes it does limit travel and articulation, the geometry is way off and there's more weight up high!
01-05-2016, 06:18 PM | #7 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
Having useed both servo on axle and cms set up yes it does restrict travel and articulation a litte bit. Is it enough to notice while driving? No not at all. |
01-05-2016, 06:19 PM | #8 |
01-05-2016, 06:30 PM | #9 | |
| Re: Any objective benefit to the 3-link panhard kit? Quote:
Also, does the panhard kit have any effect on torque-twist? | |
01-05-2016, 06:51 PM | #10 |
You don't go to a 3 link and panhard setup for better performance; you go to CMS for looks and then 3 link and panhard to make it work better than CMS and 4 link. Bottom line: 4 link is the better performing system. However, the inherent geometry problems caused by CMS are better fixed with a 3 link and panhard. The axle only shifts a few millimeters, ideally, so balance shouldn't be affected. It shouldn't affect torque twist either. |
01-05-2016, 09:07 PM | #11 |
I didn't know anyone even bothered with CMS without a panhard link. That can't possibly work, because there's nothing to ensure the steering knuckle is always the same distance away from the servo horn. The bumpsteer wouldn't just be annoying, it would be intolerable. Well, now I kinda wish the panhard kit didn't look so cool, because I still kinda want one. Maybe someday I'll build a second Wraith and make different design choices for it. Regarding your sigline, micro racer: A couple months ago I had to go to the optometrist to have an iron filing extracted from my right eye. They had to drill a (small) hole in my cornea to remove the rust. I was wearing regular glasses at the time and I thought that was good enough. I was wrong. Last edited by fyrstormer; 01-05-2016 at 09:24 PM. |
01-07-2016, 06:13 PM | #12 | |
01-19-2016, 07:26 PM | #13 |
Newbie Join Date: Dec 2014 Location: Houston
There is one potential benefit, and that's a bit more room for compression travel. Right now the thing limiting compression on my Wraith, front and rear, is that the servo hits the body. I haven't seen the CMS in real life so I can't say that it limits travel, but it does look like an okay design, so there may be some easy fix for it. Sent from my iPad using Tapatalk |
01-19-2016, 08:30 PM | #14 | |
Pebble Pounder Join Date: Oct 2009 Location: Tacoma
01-19-2016, 10:57 PM | #15 |
Quarry Creeper Join Date: May 2011 Location: Battle Ground WA
I don't regret the CMS/3link setup at all. You do lose a bit of steering power and and you get a bit of weird suspension behavior with the servo "pushing" or "pulling" on the axle rather than acting towards only steering, if that makes sense. It's a small tradeoff for the looks. Roommates Wraith is still 4link/axle mounted so I have a good rig to compare it to, it's just not enough for me to fret over.
01-20-2016, 03:59 AM | #16 |
Yeah, I was looking more closely at the setup Vanquish offers, and it's disappointing they didn't try harder to make sure the panhard link and drag link are parallel at all times. That's kind of a requirement to avoid bump-steer, not sure why they halfassed it. I mean, their setup sure looks pretty, but if it doesn't work right...I'll just keep the stock setup then.
01-20-2016, 08:01 AM | #17 |
No bumpsteer on mine Keeping the steering parallel with the panhard will also depend on how long your servo horn is, ect. |
01-20-2016, 10:08 AM | #18 | |
With the VP CMS, front axle jacking around was terrible (and you lose a small amount of up travel), worst "upgrade" I ever bought. | |
01-21-2016, 07:17 AM | #19 | |
01-22-2016, 02:53 AM | #20 |
RCC Addict Join Date: Feb 2012 Location: UK
I have had both the Vanquish CMS and now run the RC4WD CMS. I prefer the Rc4wd CMS. I prefer the way it mounts to the axle and the rigid servo mount that replaces the chassis/bumper mount. Another plus to a CMS is it keeps the servo out of the water so you can wade more. On Axle is definitely better though for ability. I also added Beef Tubes to the front to counter the weight shift.
Any objective benefit to the 3-link panhard kit? - Similar Threads | ||||
Problem with the 3 link Panhard kit | shayin | RC4WD Trail Finder 2 | 10 | 02-01-2015 12:21 PM |
vanquish cms/panhard/link kit | racer | Axial SCX-10 | 13 | 10-14-2014 10:29 PM |
help with panhard mt from vp 3 link kit | cushdog58 | Axial SCX-10 | 7 | 04-03-2014 08:28 PM |
question about 3 Link / CMS / Panhard Conversion Kit | urnot2brightru | Axial SCX-10 | 16 | 03-26-2014 06:30 PM |
