01-19-2016, 03:27 PM | #1 |
Newbie Join Date: Dec 2014 Location: Houston
| First Scratch Built Wraith
Hi all. I just finished(ish) my first scratch built Wraith. I'm still waiting for the servo for the dig box and for the body panels, but I did take it out this weekend for a short run. I built it using a HR trans and skid, Vanquish Currie front axles on both ends, MIP driveshafts, 175mm shocks, and Hitec 7955TG servos for dual steer. I'm using my Futaba 4PX to run it, and it rolls on a set of RC4WD Low Boyz 2.2 rims and a set of HotBodies Sedona white dots. Power comes from a Tekin RX8 and goes to a T8i 1450kv motor. I planned on running a 4S 2700 but took it out this weekend with a 2S 5000 for some crawling around on an old collapsed barn at my girlfriend's ranch and was pretty happy with the performance, at least for crawling. I've still got some adjusting to do and I haven't yet gone through to waterproof the electronics, but I just couldn't wait. |
01-23-2016, 01:00 PM | #2 |
My stepson and I took it out to Deer Park to the rock course for a test run. Ran two batteries through it. It was really fun. I attempted some pretty technical lines and was reasonably happy with the performance. There's some suspension jacking with the rear steer going and I beat up on the steering a little bit. I'm going to have to look into relocating the servo back and up a bit and definitely need to clock the knuckles differently. |
04-21-2016, 09:37 PM | #3 |
Rock Stacker Join Date: Sep 2013 Location: NW arkansas
| Re: First Scratch Built Wraith
What shocks are you running? Sent from my SAMSUNG-SM-G890A using Tapatalk |
04-21-2016, 10:23 PM | #4 |
Quarry Creeper Join Date: Jan 2012 Location: Central Florida
Not sure on the brand but he did say 175mm. Wow.! Scaling & Crawlin |
04-21-2016, 10:33 PM | #5 |
That Wraith is bigger than my 1:1 Jeep. I wish I could drive my Wraith around town.
04-24-2016, 12:08 PM | #6 |
Yeah I saw the 175mm and it got me looking for some to play with lol Sent from my SAMSUNG-SM-G890A using Tapatalk |
06-06-2017, 09:17 AM | #7 |
I've been away far too long. Sorry. Anyway, the shocks are Integy 175mm for the HPI Savage. I have a set of OEM Savage shocks as well and they're substantially smaller. The Integy ones leaked out in the first run, and haven't held oil since, but it really hasn't affected the rig, since almost all the weight is in the axles so it's unsprung anyway. I found a video on YouTube where a kid chopped his cage to install the longer shocks and pretty much followed that, with a few modifications to accommodate the size of these shocks. Also added the original links ala fastback conversion, but I didn't chop the cage. The idea was to stiffen things up a bit and be able to add a tow hitch. I've since reconsidered that, however. I flipped the winch mount and tucked it behind the grill to provide better protection and a cleaner look. I also added an original RTR body to it. I hate painting RC bodies so I generally get RTR replacement bodies for my RC vehicles. I have a Losi SCTE 2.0 running the TLD body as well. I took it out yesterday to the Under the Bridge location I just found out about and managed to overpower the drivetrain. The dig box's output shaft is now wobbling. I'll have to pull it apart and see what's going on there. The MIP shaft seems to be ok. I'm in the process of moving and don't want to get into tearing this thing down and risk losing the parts in the move. My stepson did snag a few photos with his iPhone while we were playing in the rock garden. I'm pretty proud of him. He drove it and did really well. I'll have to see about getting him a crawler of his own. AJ's Photo of Axial Wraith by Toe_Ball, on Flickr AJ's Photo of Axial Wraith by Toe_Ball, on Flickr |
06-06-2017, 09:30 AM | #8 |
Rock Stacker Join Date: May 2017 Location: London
Pretty good! I was contemplating putting a dig on mine. I am only just beginning the build and I had decided to leave the dig out for now and perhaps revisit it later once I have the rest of it tuned in. You mention a dig shaft wobbling in your last post. This was my concern that it would be a weak point of the drivetrain. Would you please describe it a little better. I am just looking to pick your mind on this as I am very curious about it. What dig do you use? I wonder if there is a high quality one available to compliment the Supersfaty transmission.
06-06-2017, 09:48 AM | #9 |
Sure. I use the Hot Racing trans with the dig unit built in (WRA38TP03). It's actually pretty tough, I just happen to be using a T8 1650 kv motor and am running an almost 10 lb rig (9lbs 5.6 oz with the 2S battery), so it puts a lot of stress on the driveline. I also have the clutch tightened to where I bottomed the threads on the shaft. I may even go so far as to shim it to make it a bit tighter. I've been trying to order the LockedUp Slipper Eliminator, but it's always not available. so I've got to improvise in the meantime.
06-06-2017, 10:03 AM | #10 |
Quarry Creeper Join Date: Oct 2016 Location: Hanover
Wow, your rig flexes so well. I've been really curious about the dig option. Do you find yourself using it often? More than the rear steer? It seems it's either Rear steer or Dig, usually not both. Maybe I'm wrong, which is very likely. |
06-06-2017, 10:13 AM | #11 |
I feel more or less the same that it is one or the other type of scenario. I'm sitting tight for your feedback ToeBall. |
06-06-2017, 10:34 AM | #12 |
To be perfectly honest, The rear steer gets used rarely, but when you need it, it's really good to have. It's neat to play with, but in crawling practicality, it causes bind and so it limits the speeds at which you want to run it. I find myself switching between front and rear only steering more often than 4WS or crab, but I haven't gotten to play on any REALLY technical trails yet so I'm not ready to recommend against or for it yet. I have used it some, like crawling over the 100 year old house in central Texas, where it really did come in handy, but not enough that it's intuitive. The same is to be said about the dig unit. Things haven't gotten so tight yet that the dig box was needed to get out. In fact, the servo died a few runs ago and I haven't replaced it yet because I haven't been doing much digging. If I can't figure out a good fix for the durability issue on that output I'll be ordering a SuperShafty output and ditching the dig. The Wraith has a long wheelbase so both features come into play when it gets tight, just the local spots I've been playing in haven't been much of a challenge. I keep hoping to run into others at the locations, just my bad luck to only be able to make it out at odd times. To be fair though, this rig is stull under construction. I haven't waterproofed the electronics nor am I at the final chassis layout, and I'm still working the bugs out. I'm still getting parts together, so it will be significantly more polished when finished. Last edited by ToeBall; 06-06-2017 at 10:40 AM. |
06-06-2017, 10:53 AM | #13 |
Rock Crawler Join Date: Aug 2007 Location: Philadelphia
Why not build a 2.2 Shafty at that point? Might've been cheaper and perform considerably better.
06-06-2017, 11:03 AM | #14 |
| Re: First Scratch Built Wraith |
06-06-2017, 11:34 AM | #15 | |
Thank you for this, interesting read. I suppose it is about having fun, at least for me it is. So doing it with Wraith over something "more suitable" is part of the process. I just came back from a muddy forest. Only have done half a pack there with nothing technical whatsoever but it was a good laugh. Amazing hobby we share Quote:
First Scratch Built Wraith - Similar Threads | ||||
Another scratch built JK | rottenbelly | 1.9 Scale Rigs | 36 | 11-14-2011 05:46 PM |
Scratch built | rag6 | Newbie General | 2 | 06-30-2011 07:50 AM |
Scratch built 2.2 | Kamikaze | Tamiya Clod Buster | 26 | 09-11-2007 07:51 PM |
My scratch built wk crawler... | billet works | HPI Wheely King | 40 | 08-15-2007 10:27 PM |
