01-20-2016, 09:18 PM | #1 |
Rock Stacker Join Date: Dec 2015 Location: East TN
| Wraith gets slower the longer it's run
I have a wraith with stock electronics (20t motor and ae5). When running it on a 3s it gets slower the longer I run it. Running it on 2s I have no issues. When running it on 3s it will get noticeably slower within a couple minutes of running on a full charge, like half speed. I don't think it's the battery because it acts the same with two separate 3s lipos and the batteries are fine on other trucks. Not sure if the 3s is possibly overheating the esc or motor but neither is noticeably hot to the touch. Any ideas on what be causing this? Thanks |
01-20-2016, 09:22 PM | #2 |
Quarry Creeper Join Date: Oct 2014 Location: yakima
| Re: Wraith gets slower the longer it's run
As far as I know and I could be wrong but I don't think thats suposed to be ran on 3s again I could be wrong think that motor is only 2s Sent from my SM-N910V using Tapatalk |
01-21-2016, 04:43 AM | #3 |
Quarry Creeper Join Date: Dec 2015 Location: ossipee
Chances are its overheating check temps when it starts to slow should not be over 150
01-21-2016, 10:09 AM | #4 |
I've not been able to find any ratings for the axial 20t motor but I'm sure that is where the problem is now. Today I ran a full 2s battery with no issues. Put in the 3s and in under 2 mins it slowed to a crawl and the magic smoke started pouring out the motor. I let it cool down and it will still run great on 2s. Just gonna get a new motor and be done with it. Thanks
01-21-2016, 11:28 PM | #5 |
Pebble Pounder Join Date: Apr 2013 Location: Charlotte, Mi
That esc is 3s capable and I have run my 20t axial motor on 3s plenty and it was fine.
01-21-2016, 11:58 PM | #6 |
check your mtr's pinion/spur mesh. ensure that there is a slight backlash. check your drive line to ensure it rolls freely remove the mtr's pinion gear and observe How many batt. cycles have been run thru ? brushes don't last forever on a 20T sporting 3s Could be you've simply worn it out ? Put a different motor in and see if the same scenario plays out. RTR ? factory 80/20 with a 20T mtr ? Is your ae5 set to LiPo ? W an LVC ? |
Wraith gets slower the longer it's run - Similar Threads | ||||
looking for longer run time... | buggynutt | Electronics | 26 | 04-17-2013 09:36 PM |
Longer run times... | turtleshuffle | Losi Micro-Rock Crawler | 36 | 06-14-2010 02:28 PM |
longer run times??? | 84socal | Newbie General | 12 | 11-02-2008 12:02 PM |
I want a longer run time | zeroskater9111 | Newbie General | 11 | 01-22-2008 09:50 PM |
