01-24-2016, 02:39 AM | #1 |
Newbie Join Date: Nov 2015 Location: Surrey
| Wraith extended stroke mod
Hi all new to this crawling trailing side of rc just finished building my wraith and now waiting on esc and motor I've fitted the yeah racing lowering kit and was thinking of fitting this ( tamiya 54519 ) to get more articulation. Was wondering if any one has done it before? Think I'm gonna order it up anyway and will post up sone pics of my wip when it's finished. Can't Wait to get it muddy
01-24-2016, 06:16 AM | #2 |
RCC Addict Join Date: Feb 2008 Location: your back yard
| Re: Wraith extended stroke mod
Can't your lowering kit be used as a lift kit? Maybe I'm missing something but not understanding.. Must get coffee.. |
01-24-2016, 07:04 AM | #3 |
RCC Addict Join Date: Feb 2012 Location: UK
To much articulation can be a bad thing. I'd leave it and test as is. In general all wheels on the ground is obviously good news for traction but if you have too much flex you find wheels dropping down holes where normally the other wheels would just drag it across. If your in rocks this normally leads to binding or flipping. |
01-24-2016, 09:16 AM | #4 | |
| Re: Wraith extended stroke mod Quote:
01-24-2016, 09:18 AM | #5 |
| Re: Wraith extended stroke mod |
01-24-2016, 09:54 AM | #6 |
Quarry Creeper Join Date: Jun 2015 Location: Athol, Massachusetts
That would be a lot of work with no payback.
01-24-2016, 09:55 AM | #7 |
The wraith is a total different animal you don't need them. Imo
01-25-2016, 09:30 PM | #8 |
Newbie Join Date: Dec 2015 Location: Québec
I make it for mine... And the front And I agree if you put it on the back it will flip on deep hole... I swap for this setup and it seem really perfect for now... Envoyé de mon Nexus 6 en utilisant Tapatalk |
01-25-2016, 10:02 PM | #9 |
As you can see... The front tire always touch the ground ... So I Think it s good for the front... But the rear at same height... The tire lift up... So it will not flipping over anymore... And if I need I can get huge crazy flex... I use 1/8 stock for stiffer spring... The crawl Master around here tell me if it's good or not... I Never participate to a competition... But it crawl really well at my local Hs... Hope it's help you!! Envoyé de mon Nexus 6 en utilisant Tapatalk |
01-25-2016, 10:14 PM | #10 |
A Quick look how I build the front pivot shock mounting by reversing the shock mount in my frame...and I use 90mm gmade on sprung set up.... Envoyé de mon Nexus 6 en utilisant Tapatalk |
01-26-2016, 10:04 AM | #11 |
Rock Stacker Join Date: Oct 2015 Location: Kingston, WA
I can see how that will be amazing for crawling in a lot of situations, but how does it react at higher speeds? |
01-26-2016, 10:48 AM | #12 |
It react really well for now on grass or dirt...its for sure not a Basher cause speed is not so fast I just got a 2100kv on 12T... I Just reverse the rear shock mount so it will drop another 1/2po...i will test and let you Know! Envoyé de mon Nexus 6 en utilisant Tapatalk |
01-26-2016, 03:59 PM | #13 |
That's got crazy flex, Might try it out on the front then. are they just bomber arms on the rear? |
01-26-2016, 04:24 PM | #14 |
No it's the blue monkeys trailing arms ... http://www.bluemonkeyrc.com/catalog/...roducts_id=239 Send by drone! |
01-26-2016, 07:04 PM | #15 |
Newbie Join Date: Dec 2014 Location: Houston
The drop free mounts were a fad for a while in the early 2000's on 1:1 crawlers, but were ultimately given up as a bad idea. The problem with such a setup is that there's no good way to damp the suspension movement with the link sagging and it creates a dead zone where the shock can't work, period. This created situations where the rig would "bounce" on descents and made it very unstable. If you want more travel, install a longer shock. If you want it to sit lower, move the top mount up. I'm running 175mm shock in m,y wraith and can nearly get my axles perpndicular to each other without any undamped suspension movement. |
01-26-2016, 08:26 PM | #16 |
In theory it'll offer more articulation, albeit uncontrolled. Articulation isn't everything however.
01-26-2016, 08:32 PM | #17 | |
This thread needs to be posted on Facebook so it can be linked back to the Facebook fail thread in chit chat. | |
01-26-2016, 08:34 PM | #18 |
| Re: Wraith extended stroke mod All of us have been or will be there at some point, it's cool to see in the beginning I suppose.
01-26-2016, 08:47 PM | #19 |
| Re: Wraith extended stroke mod I tell all my younger or more inexperienced friends that I've already done all the stupid stuff they're thinking about doing so they should let my stupidity be their teacher. |
01-27-2016, 12:37 AM | #20 |
OK...so i'll try without to see the difference...i suppose your right and explain why big compagnie like axial, vanquish or srtc dont make it... thanks teacher ! Envoyé de mon Nexus 6 en utilisant Tapatalk |
Wraith extended stroke mod - Similar Threads | ||||
Built AX-10 tranny with extended outputs in Wraith | Trugg | Axial Wraith | 3 | 12-09-2013 10:22 AM |
wraith extended wheelbase | BIG T | Axial Wraith | 0 | 01-02-2013 01:52 PM |
DX3 extended battery life mod | Krawler Freak | Electronics | 15 | 04-14-2007 11:28 PM |
