01-29-2016, 01:11 PM | #1 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| more steering out of the ar 60
vp knuckles and cs. axial universals. what can be done to get even more throw? was going to try scx10 axle with xr mod. this looks to be a cheaper. thanks a lot |
01-29-2016, 02:05 PM | #2 |
| Re: more steering out of the ar 60
IMO the Wraith (kit form) with included universal's steers very well. Clearly the Universal's travel capability is the limiting factor here. Tho' a standard two channel radio likely doesn't allow for enough steering fine tuning/adjustment. But a better TX will. If you need more steering control once the full steering arch/throw is set/established. The only other option is to change the axle gears. Realize that locked 4X axle's tend to push the rig thru corners because both front and rear axles drive at the same speed. Changing the front axle's R&P gear to less teeth will net more steering capability. Because the front tires will spin faster then the rears. search axle underdrive/overdrive to know more. ------- another thing that effects the steering is... the tire's density or being too soft. (proper foam inserts control this) Too soft and the tire will deflect/scrub more, reducing steering output/control. While a stiffer tire will steer better. It will also lose some traction qualities. So realize that having softer or stiffer tires can often be a trade off. Last edited by TacoCrawler; 01-29-2016 at 08:07 PM. |
01-29-2016, 02:22 PM | #3 |
Rock Crawler Join Date: Jan 2008 Location: P-TOWN
The SCX/AX10 housing XR mod will not give you any more steering than you have now. The universals can only go so far before they start to bind. If you want more , you can modify the universals to give you a little more but that weakens the integrity of the universal IMO. Dlux sells pre modded universals that he claims to give up to 70* of steering.
01-29-2016, 07:42 PM | #4 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
Replace the gearing in the differentials. Either stock HD bevel in the front with underdrive in the rear, or overdrive / under drive. This will allow the front wheels to spin faster and pull it around.
02-01-2016, 06:07 AM | #6 |
no sure what axle that is. hell of a lot of steering.. I look at there site. 70* of steering. would think that would hit the axle link and shock..
02-01-2016, 11:19 AM | #7 |
The xr mod will give you a lot more steering than the available shafts for the ax axles can. The problem is you be running into the links and shocks long before you run out of angle.
02-01-2016, 07:44 PM | #8 | ||
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
| Re: more steering out of the ar 60 Quote:
Yep, the xr mod will add steering to the ax axle, but you can't really xr mod an ar60......unless...you add an xr10 gearbox between ar-60 tubes....that's not really on topic.. [/sarcasm] | ||
02-01-2016, 08:55 PM | #9 |
Pebble Pounder Join Date: Dec 2012 Location: Vancouver
Most 1:1 4 wheel drive trucks use double cardan shafts for the front driveline. Whether that's an application that can be used on a crawler or someone makes them..Not sure.
02-01-2016, 09:22 PM | #10 | |
Dammit. I read stucks's post and my head went xr mod not existing ar60. Which is the way I got here. Ax, xr modded ax and now all the good bits from the ax axles are in ar60's. | |
02-01-2016, 09:34 PM | #11 | |
This is what he is using instead of a universal or dogbone This is a pic of the amount of steering. | |
more steering out of the ar 60 - Similar Threads | ||||
Steering/Alignment Problem After Install RPM Steering Knuckles? | Barzan724 | Newbie General | 2 | 01-21-2016 06:32 PM |
Idea for scaler steering... Need ideas for building a steering box. | JavelinSST390 | General Scale Talk | 25 | 05-14-2015 02:32 PM |
inside tyre touches steering knuckle / steering linkage | murky123 | Axial SCX-10 | 4 | 10-06-2010 04:46 PM |
Hot Racing Steering knuckles - more steering than the original plastic ones? | Tomy | Axial AX-10 Scorpion | 1 | 11-16-2008 11:26 AM |
