03-20-2016, 06:15 PM | #1 |
Newbie Join Date: Sep 2015 Location: Bucyrus
| Swapping out AX10 Deadbolt for Wraith
After having my Deadbolt for a little over 1 year I decided I wanted something more scale looking as my 2.2 rig. I set out on EBay and picked up a mostly complete wraith chassis so I could start swapping out everything that I could. while swapping out the tranny, I upgraded to some Robinson Racing gears and new Fast Eddy bearings. Currently waiting for a new spur gear before I mount up the electronics. Here is some pictures of my progress on some diy panels. There were sloppily made but they work. Sent from my D6616 using Tapatalk |
03-20-2016, 07:22 PM | #2 |
Rock Stacker Join Date: Mar 2014 Location: Albuquerque
| Re: Swapping out AX10 Deadbolt for Wraith
What did you use as hinges for the reverse opening hood? And actually those panel are pretty wicked. Also which front mount plate is on that? if you happen to know. TraneDrift |
03-20-2016, 07:40 PM | #3 |
I used parts 3 or 6 off the AX80085B tree. I also used some plastic spacers but don't recall the parts tree, they are maybe 1/4 thick. The prevent the hinges from getting too tight around the bar they mount to. I used magnets and washers for the magnet to grab at the other end. I'm not sure on the plate as it came from the owner I had bought it from installed that way. Thanks for the comment about the panels. I had to use oversized screw heads to cover some elongated holes made during panel fit up. Sent from my D6616 using Tapatalk |
03-20-2016, 07:44 PM | #4 |
Ah those pieces thankfully I have a scx10 deadbolt laying around with those parts! TraneDrift |
03-24-2016, 07:12 AM | #5 |
Newbie Join Date: Jul 2015 Location: Oregon
That's exactly where I am, I love my deadbolt just tired of the deadbolt body, especially after installing proline XL tsl's and having to hack up the fenders, may have to look at doing this to, basically all you need is the wraith tabular frame?
03-24-2016, 09:34 AM | #6 |
You need the frame, the wraith transmission case, the wraith specific lower gear, a new bearing for the lower gear. It has an extended output on one side for the wraith transmission and because the bottom skid is longer. Sent from my D6616 using Tapatalk Last edited by Swift Fox; 03-24-2016 at 11:36 AM. |
Swapping out AX10 Deadbolt for Wraith - Similar Threads | ||||
AX10 deadbolt body on SCX10 deadbolt | BrianP | Axial SCX-10 | 3 | 11-08-2015 04:51 PM |
AX10 Deadbolt turned into a Wraith | VTHokie | Axial Wraith | 8 | 05-15-2015 08:13 PM |
wraith vs ax10 deadbolt vs sxc10 | nerby149 | Newbie General | 13 | 01-16-2015 06:45 PM |
