Thread: Vera + Mattzilla = Verazilla!
Old 03-20-2016, 11:35 PM   #1
Default Vera + Mattzilla = Verazilla!
I bought the Roland Rock Shop 2015 Axialfest U4 build Mattzilla chassis to be assimilated by my Wraith (Vera) to create VERAZILLA.
This will be my scale G6/U4 tank and the old Wraith chassis will be used for Levior.
It may have been bad timing to undertake this project with only two weeks before the Oregon RECON G6, but I'm on vacation this week and some motivation always helps speed things along.
I made a ton of progress in just the past couple of days and was able to test drive the beast a bit today. It definitely needs tuning!
The front axle was a straight bolt-in. The ESC needed a support bracket but this end was easy.
Name:  Vera Upgrade 01.jpg
The rear got trailing arms and dual shocks. I'm still working on finding the sweet spot for the dual shocks with limiting straps but it's looking awesome. An un-anticipated but very cools feature is the ability to rotate the shock mount bracket to change the relative compression of the two shocks. This is great for tuning and I'll lock it down once I find the best position. The Krawler shocks are a bit sticky so I need to tear them down and see what's going on.
Name:  Vera Upgrade 04.jpg
Name:  Vera Upgrade 03.jpg
This is where things got real interesting...I opted for a Bomber skid to take advantage of the trailing arm mounts and additional link mounting options. Three of the four mounting holes on each side line up so it bolts right in.
Name:  Vera Upgrade 02.jpg
To accommodate my AX2 transmission a little modification was required. I drilled new holes to match the Wraith skid and cut away a section of the skid 'hump'.
Name:  Vera Upgrade 06.jpg
Name:  Vera Upgrade 07.jpg
I also created a spacer so the transmission would have a full contact area rather than resting on a few of the skid ribs.
Name:  Vera Upgrade 08.jpg
I still need to decide what to do with the big hole but for now it works. Only time will tell if it lasts
Name:  Vera Upgrade 05.jpg
Items I still need to figure out before the RECON G6:
  • Electronics box (the fuel cell might work)
  • Mounting the light bar
  • Winch mounting options
  • More suspension tuning
mikebecher is offline   Reply With Quote
Old 03-21-2016, 02:38 PM   #2
Default Re: Vera + Mattzilla = Verazilla!
what type of material is that spacer you made?
Like the way you're going with this truck!
NWHavok is offline   Reply With Quote
Old 03-21-2016, 02:53 PM   #3
It's Sculpey polymer clay I stole from my wife. I pressed it into the skid and baked the whole thing (skid included) at 250° for about 10 minutes. After that it was rigid enough to remove and bake by itself for another 20 minutes at 285°. Once cooled it is surprisingly strong and can be drilled, sanded or cut.
Old 03-23-2016, 09:20 PM   #4
I got my electronics box installed today and am just buttoning up the wiring. There was a break in the rain so I took it out for a test drive. At speed it handles soooo much better than stock thanks to the lower COG. That also improves the crawling ability although it does hang up a tiny bit more than before.
Next up - lights and body panels. It's getting close now
Name:  Vera Upgrade 09.jpg
Name:  Vera Upgrade 10.jpg
Name:  Vera Upgrade 11.jpg
Old 03-24-2016, 08:33 PM   #5
If the G6 was tomorrow I'd be ready!
But since I still have a week I'll keep tweaking and testing. Here's what I have so far...
Name:  Vera Upgrade 12.jpg
Name:  Vera Upgrade 13.jpg
Name:  Vera Upgrade 14.jpg
Name:  Vera Upgrade 15.jpg
Name:  Vera Upgrade 16.jpg
Old 03-24-2016, 08:54 PM   #6
Really nice work you have done with that chassis.
bilinvic is offline   Reply With Quote
Old 03-24-2016, 11:50 PM   #7
R those tires 2.2 Xl?
Bryson25 is offline   Reply With Quote
Old 03-25-2016, 12:42 AM   #8
Yes they are.
Old 03-25-2016, 10:30 AM   #9
Really like what you've done with this. Everything looks super clean.
Old 03-25-2016, 12:08 PM   #10
Thanks! My dirty little secret is to just hide it all. Now I know where my kids get their room 'cleaning' skills
Name:  Vera Upgrade 17.jpg
Name:  Vera Upgrade 18.jpg
Name:  Vera Upgrade 19.jpg
Name:  Vera Upgrade 20.jpg
Old 03-25-2016, 01:05 PM   #11
What did you use to mount the lite bar
ossipeecrawler is offline   Reply With Quote
Old 03-25-2016, 01:32 PM   #12
Hah, glad you asked. It bugged me for the longest time that I couldn't find a good way to mount to 5" light bar on the Wraith chassis. Mounting on top of the roof is not really an option for me unless I want to destroy it. I got a Gear Head RC 1/10 Scale Light Bar Hood Mounting Bracket Kit from RPP. I have to zip tie them to the Mattzilla chassis but it seems to work OK. On the plastic chassis I just screw them directly into the rail.
Name:  Light Bar Mount 1.jpg
Name:  Light Bar Mount 2.jpg
Old 03-26-2016, 07:22 AM   #13
Man this rig is sick! Really well done my man. Very clean, low and mean.
BadWagon is offline   Reply With Quote
Old 03-28-2016, 01:10 PM   #14
Alright! Killer build. Competion I'm drawn from the guava now and I brought a tig welder and vac form table hahahaha you might regreat this Mike!
AK-49 is offline   Reply With Quote
Old 03-28-2016, 02:19 PM   #15
Thanks for the tip with the light bar. wraith looks great!!
Old 06-01-2016, 05:47 PM   #16
Thanks for the compliment! I haven't updated this thread in a while either. This is the rig I took to the April Fowl RECON G6 in Oregon a couple months ago. Aside from blowing out my plastic spur it did great, including earning me 2.2 Driver of the Day honors
The copper pan clock is Parker's way of trying to be funny and implying it's 'time' to graduate from 2.2 and move on to 1.9 class.
Name:  Oregon Trip 08.jpg
My mangled plastic spur. I was able to finish the day on this but clicked the entire time.
Old 08-10-2016, 11:10 AM   #17
Where did you get that box in the rear for the receiver and BEC?
slapjack is offline   Reply With Quote
Old 08-10-2016, 03:37 PM   #18
I found mine at RadioShack. Most electronic parts stores should carry em. They come in different sizes...
DeviledEggs is offline   Reply With Quote
Old 08-11-2016, 12:22 AM   #19
It's this one: Hammond Manufacturing 1591XXLBK
It's mounted with a single piece of aluminum bent into a cradle and around the frame secured with screws.
Old 08-15-2016, 05:54 PM   #20
Thanks... Another question. What mount is that you have off the back of the transmission where he dig servo normally would sit? I have 2 ax10 servo mounts I was Gna attached in an L shape to stick my esc and receiver on but with the ax10 one I can only get one screw in each piece. That one you have hasall 3 screws in it.
