03-23-2016, 07:00 AM | #1 |
Newbie Join Date: Jul 2013 Location: Ashland
| breaking bolts in hd gear sets
so little bit of info for you. motor: tekin roc 412 3100kv esc: holmes trail master battery: 3s 45c gearing: pinion: 16tooth spur: 68 tooth diff gearing: 36/14 insicion spools for front and rear will be here Friday... so my issue is that I am shearing the bolts that bolt my ring gear to the diff cup. this has happened twice now with the first time it accually shearing the bolts and tearing the diff cup apart. I do have the drag break turned up pretty high and I feel this could be the issue but I do beat on it pretty hard when I'm out crawling. ive got everything else pretty much bullet proof and haven't broken anything else for a very long time its all vanquish so... I do currently have the stock diff cups and lockers installed but fear that with a full metal spool it will increase the harshness on the bolts I keep shearing. anyone have any suggestions for me. id really like to keep my drag break where its at. Thanks in advance |
03-23-2016, 07:35 AM | #2 |
| Re: breaking bolts in hd gear sets
Sounds like your screws were loose. Under torqued hardware will fail before over torqued. Loctite the screws in the new spools and I bet your issue goes away.
03-23-2016, 07:41 AM | #3 |
I have never had this problem but there are a few things that may help. Since the HD gear sets are helical cut, they exert some force outward on the gear. This force may be pulling the screws out of the plastic diff cup enough to cause some play between the diff cup and the gear leading to snapped screws. The Incision lockers should prevent the screws from backing out (as long as you remember to use thread lock, we have all forgotten it at some point ). The other thing may be the screws themselves. Cheap grade 8.8 hardware only has about 2/3 the tensile strength of grade 12.9 hardware. Stainless steel would be even weaker than the grade 8.8 stuff. Get some quality grade 12.9 screws, you can buy them in quantities of 100 from fastener stores or in smaller quantities from Amain. https://www.boltdepot.com/Product-De...?product=13323 ProTek RC 2x6mm "High Strength" Socket Head Cap Screws (10) [PTK-H-1003] |
03-23-2016, 03:43 PM | #4 |
Thanks guys I'll give it a try and see what happens.
03-23-2016, 03:50 PM | #5 |
And svt923 if you where closer I'd give you a big wet kiss. You even took the leg work out of it for me by posting links to what I need. Your the best thanks a lot.
breaking bolts in hd gear sets - Similar Threads | ||||
bruiser u-bolts fit on yoga axles? home made u-bolts anyone? | cydog510 | RC4WD Trail Finder 2 | 4 | 06-26-2012 12:27 PM |
Gear Sets | Rooney7783 | Tamiya TLT Crawlers | 4 | 10-14-2005 08:21 AM |
breaking bevel gear shaft txt-1 | Kev808 | Tamiya Txt-1 and Juggernaut | 4 | 07-06-2005 03:17 PM |
