03-27-2016, 04:04 PM | #1 |
Newbie Join Date: Dec 2013 Location: Omaha
| No Reverse
I have a wraith but I think this is an electronics problem. I cant get reverse to work. I run a brushed setup and have replaced everything trying to get this fixed. I am currently running the holmes hobbies ble esc with a castle bec and a brushed holmes hobbies motor. I have used castle link to set the esc to brushed and crawl reverse. No luck. I replaced the stock receiver with a futaba 3pm-2.4g mx fast. I can't figure this out any suggestions???
03-27-2016, 06:01 PM | #2 |
Rock Stacker Join Date: Feb 2016 Location: South MS
| Re: No Reverse
Have you checked the settings on your transmitter? But chances are its in the ESC settings. I know a lot of dirt racing (and carpet) require you to remove the reverse setting when racing and I am 99% sure they do it via the ESC. |
03-27-2016, 06:30 PM | #3 |
| Re: No Reverse
I used the castle link to program the esc. I have it set for crawler reverse. This is baffling me but I'm sure its something silly I am missing.
03-27-2016, 07:16 PM | #4 |
| Re: No Reverse
Maybe this will help. I have never used that type of ESC, but my buddy was having somewhat similar issues setting up his ESC on his Associated B5. |
03-28-2016, 04:49 PM | #5 |
| Re: No Reverse
That video was very helpful. I still cant get reverse to work. It is like the controller is not sending a reverse signal. It does exactly like the video says for forward throttle and then when I switch to reverse throttle the ESC never seems to get a signal.
03-28-2016, 05:45 PM | #6 |
| Re: No Reverse ^ video link fail, for me, but maybe it demonstrated set up procedure (TX - ESC calibration) !? so besides the binding process and ESC programming... did you do the set up procedure (calibration) for the TX - ESC ? ie: plug battery in to ESC... ~ assuming all is connected/properly ~ while holding TX full throttle listen for beeps, then reverse listen for beeps, then neutral. Lights stop blinking I guess. (follow the instructions below) ^ helps to have four hands Lol http://holmeshobbies.com/public_file...structions.pdf Last edited by TacoCrawler; 03-28-2016 at 06:00 PM. |
03-28-2016, 06:52 PM | #7 |
| Re: No Reverse
Yes, that is what I am doing but the ESC never recognizes the reverse throttle.
03-28-2016, 07:28 PM | #8 |
| Re: No Reverse
I think I figured it out. The controller had throttle reverse programed into it. I turned it off and now both directions seem to be working.
No Reverse - Similar Threads | ||||
Need Help: ROC 412 Sensored=Reverse Only, Sensorless=Forwards/Reverse | jeepnvinny | Electronics | 5 | 03-01-2014 08:21 PM |
Help! No Reverse... | 1BAMFR | Non Crawler RC's | 1 | 08-26-2013 09:14 PM |
novak eiger pro green led flashing in reverse No Reverse sometimes | burmis | Electronics | 2 | 05-22-2013 09:04 PM |
Reverse is gone D; | Lemonlegs28 | Axial SCX-10 | 3 | 03-24-2011 11:06 PM |
no reverse? | bradabolics | Electronics | 1 | 03-19-2010 10:10 PM |
