04-02-2016, 02:10 AM | #1 |
Newbie Join Date: Apr 2016 Location: Greece
| Stock ESC OR MOTOR BURN..???
Hello, I've just finished replacing all screws in my Wraith Spawn which doesn't look like a spawn quite a long time since I've made my own exterior ferings changed the steering bar added lights and stickers and enjoyed the rig for the past two months in almost every surface!!!! When I placed the stock esc and all the electronics and put my 2s lipo 4000 mah which is good for the stock AE-5 Esc and was working since now some the rig rolled without turning on the power switch or the transmitter and smoke came out from the esc... I removed the battery checked everything and put back again and the same happened. Smoke out from esc and rig moving without switching on. Now questions... Is the stock esc burnt or the motor? If esc is burnt what alternanates do I have to keep playing with my stock motor and be prepared for the next motor upgrade? If the motor is burnt which is the next step for more bashing which the stock esc? Thanx |
04-02-2016, 02:29 AM | #2 |
RCC Addict Join Date: Apr 2009 Location: LA
| Re: Stock ESC OR MOTOR BURN..???
I think it's safe to say that the esc is toast. To test the motor, touch its wires to the battery and see if it moves; try it reversed also.
04-02-2016, 07:29 AM | #3 |
Thanks man, what's your opinion about the new esc? Shouldn't it be one much better to welcome a new motor in the future? Which one do you suggest? |
04-02-2016, 07:32 AM | #4 |
| Re: Stock ESC OR MOTOR BURN..??? |
04-02-2016, 08:04 AM | #5 |
Quarry Creeper Join Date: Jun 2015 Location: Athol, Massachusetts
If you think you'll ever go brushless get a castle mamba max pro, or Holmes Hobbies TrailMaster BLE Pro depending what available to you. They both will work with brushed also so you can upgrade whenever. |
Stock ESC OR MOTOR BURN..??? - Similar Threads | ||||
did I burn out my stock speed control and motor? | DTA510 | Axial SCX-10 | 8 | 12-17-2015 01:35 PM |
Motor noise help! Dont want to burn up motor | farrell93 | Electronics | 2 | 11-10-2012 02:30 AM |
550 can 21T, will it burn out the ESC? | Elliott000 | Axial Wraith | 8 | 09-05-2011 04:40 PM |
ESC burn out? | TwistedCrawls | Axial SCX-10 | 0 | 05-11-2010 07:52 AM |
