MS Racing's UnWraithed Wraith I'm starting a new thread to point out what I am doing with my wraith. I have been wheeling full size rigs for years now and spent years before that racing snowmobiles. I spent a lot of time learning about suspensions and how they work. I also wheel with top level competitors in class 4 RcRocs and have learned a lot from them as well. As I built my full size rig, I studied a lot about link design and the use of a 4 link calculator before building the current suspension in my rig. I decided to take the same approach with this one. I intend to use all my knowledge to improve the suspension and overall performance of the wraith. Some of my ideas may seem a bit strange or way out of the box, but what fun would there be doing something boring like everyone else. I won't always show or describe exactly what I am doing, I want to leave it up to you all to think a little with me. So lets have fun and see where this goes. for those following my last thread, some of this will be the same, I apologize. Lets hope this one doesn't get pulled off the tracks. |
Re: MS Racing's UnWraithed Wraith Here's what I'm starting with, the back was chopped off and some upgrades were installed. http://uploads.tapatalk-cdn.com/2016...ef46cbe580.jpg Sent from my SM-G920V using Tapatalk |
Re: MS Racing's UnWraithed Wraith Subscribed again J.A.W - just another wraith & a Bomber! |
Re: MS Racing's UnWraithed Wraith Specs Motor Tekin Roc 412 3100kv previous Axial 20t brushed ESC Castle Creations Mamba Monster X previous Tekin RX8 Gen2 Axial AE-5 Servo Savox SW-1210SG Battery Orion Carbon Pro 4500 Trans Axial metal gears Axial Dig w/traxxas servo AE 12t 48p pinion Robinson Racing 93t 48p Spur Axles Axial Underdrive 43/13 ring and pinions front and rear Axial metal diff cover Axial universal style front axle shafts Axial locker front prototype MSR rear diff Wheels Super Shafty 2.2 Prangs orange anodized Tires Proline BFG KR2 2.2 previous RC4WD TSL Boggers Inserts front MSR H2bb rear MSR 2sfzr Suspension Shocks Waiting patiently for Proline 5" powerstrokes currently 120mm unknown brand 35wt oil small piston holes MSR rear link/shock mounts Titanium lower links front/rear Radio Futaba 4PX Winch RC4WD Warn w/ wireless remote I'll try to keep this updated as things go |
Re: MS Racing's UnWraithed Wraith My full size crawler sitting on 39" red label BFG'S http://uploads.tapatalk-cdn.com/2016...0c6ece2495.jpghttp://uploads.tapatalk-cdn.com/2016...4189c7c6e3.jpghttp://uploads.tapatalk-cdn.com/2016...db281d18ae.jpg Sent from my SM-G920V using Tapatalk |
Re: MS Racing's UnWraithed Wraith I started by measuring the rig and scaling it up to enter it in my 4 link calculator. Based on the numbers, there is a lot that can be done to drastically improve the climbing ability. http://uploads.tapatalk-cdn.com/2016...286b6c8e98.jpghttp://uploads.tapatalk-cdn.com/2016...ee808c2c40.jpg Sent from my SM-G920V using Tapatalk |
Re: MS Racing's UnWraithed Wraith Next I spent some time changing the links to maximize stability as well as climbing performance. http://uploads.tapatalk-cdn.com/2016...6f97ca100f.jpghttp://uploads.tapatalk-cdn.com/2016...88525855a3.jpg Sent from my SM-G920V using Tapatalk |
Re: MS Racing's UnWraithed Wraith I needed to figure out a way to see if my changes were going to work as planned. I disconnected the front driveshaft and propped the front tires up on a box and added weight to the box until the rear tires could not push it across the carpet any longer. I did the same after changing everything to the new link design and I could easily push the weight that the old system could not. This tells me that the weight of the rig is now being transferred better to the rear tires, providing more traction. The next test will be real world to see if it climbs better. |
Re: MS Racing's UnWraithed Wraith Here's the awesome Super Shafty Prangs with the new Proline KR2'shttp://uploads.tapatalk-cdn.com/2016...6d80145e5d.jpghttp://uploads.tapatalk-cdn.com/2016...2adc7f33d2.jpg Sent from my SM-G920V using Tapatalk |
Re: MS Racing's UnWraithed Wraith So out to my test spot to try out the new suspension. I am not using the dig function here on these climbs. The rear diff is close but still needs a little more work. https://vimeo.com/161324143 Sent from my SM-G920V using Tapatalk |
Re: MS Racing's UnWraithed Wraith |
Re: MS Racing's UnWraithed Wraith And a few pics http://uploads.tapatalk-cdn.com/2016...f105c64e20.jpghttp://uploads.tapatalk-cdn.com/2016...9ec8794c5d.jpghttp://uploads.tapatalk-cdn.com/2016...786ba533de.jpg Sent from my SM-G920V using Tapatalk |
Re: MS Racing's UnWraithed Wraith I had posted this pic earlier on my old thread that had a few wondering what was going on http://uploads.tapatalk-cdn.com/2016...df738b52f1.jpg Sent from my SM-G920V using Tapatalk |
Re: MS Racing's UnWraithed Wraith I was pretty happy with the rear foams for the most part but wanted them just a little stiffer. I put them in the freezer with 1 bead ring off each wheel. Ten minutes later I put the ring back on then took them out. The air inside expanded as they warmed up to room temperature giving them a little bit of air pressure. http://uploads.tapatalk-cdn.com/2016...e8553ca4b8.jpg Sent from my SM-G920V using Tapatalk |
Re: MS Racing's UnWraithed Wraith I was also not that happy with the boring shape of the "body" so I narrowed it up a little to give it a bit more shape. Sent from my SM-G920V using Tapatalk |
Re: MS Racing's UnWraithed Wraith Before and after http://uploads.tapatalk-cdn.com/2016...b6375bc451.jpg http://uploads.tapatalk-cdn.com/2016...f23da5db18.jpg Sent from my SM-G920V using Tapatalk |
Re: MS Racing's UnWraithed Wraith I'm also not sure how much I like the roof on it. My 1:1 is open top too. http://uploads.tapatalk-cdn.com/2016...1ef36b1b47.jpg Sent from my SM-G920V using Tapatalk |
Re: MS Racing's UnWraithed Wraith As you can see in the last pics, I'm also in the middle of installing the new esc and moving everything around. I picked up some scales so I can get my weight balanced out while I'm at it. http://uploads.tapatalk-cdn.com/2016...047ecaa036.jpg Sent from my SM-G920V using Tapatalk |
Re: MS Racing's UnWraithed Wraith If I had a crawler as nice as your 1:1 I would punt my wraith off mountain and never look back |
