Currie axles I have the front axle already and was wondering would a center be better for the rear or the offset |
Re: Currie axles Depends on where your trans output is. Left/right, or center? Ideally you want your rear drive shaft to be in as strait a line as possible. So go from there. |
Re: Currie axles Looking at the back of mine, the tranny output is slightly off to the driver's (left) side. Id say the centered diff looks like it would be just a little better for the driveshaft angle. And it arguably looks cooler... |
Re: Currie axles You can use either with the Wraith without any issues. http://i663.photobucket.com/albums/u.../3Jan15_06.jpg |
Re: Currie axles Yup, Wraith tranny output sits right in between both the offset and centered diff, it's the same angle either way. |
Re: Currie axles I ordered the offset for this build |
